Bronco II Ford Bronco II
Rough Idle
Old May 14, 2001 | 01:24 PM
jimmyfoddrell's Avatar
jimmyfoddrell
Rough Idle
I have a 1987 Bronco 2, 4wd, AT, 2.9L engine.The truck has a rough Idle. I ran a diag for the codes and got 33 and 34. I replaced the ERG valve, cleared the codes, but they returned. I replaced that ERG with another one, again cleared the codes, but they re-appeared. I checked for vacuum leaks but could not find any. I am out of ideas. Any help is appreciated.
Old May 14, 2001 | 03:05 PM
josh3972's Avatar
josh3972
Rough Idle
when i first got my '86 it had a rough idle. i replaced the Idle Air Control valve and the Throttle Position Sensor and the idle now sits at 900rpm and doesn't move.
Old May 14, 2001 | 03:15 PM
jimmyfoddrell
Rough Idle
Are they difficult or expensive to do?
Old May 15, 2001 | 09:44 AM
josh3972's Avatar
josh3972
Rough Idle
they both are on the left side of the intake as you are standing at the front (you can't miss them). they are held on with 2 screws each with 2 wires running out of them. unscrew them then unplug them, plug the new one in and screw it back on and thats it. (couldn't be easier). the idle air control is about $80.00 and the throttle position sensor is about $45.00 from Ford.
Old May 15, 2001 | 10:13 PM
redbronco2's Avatar
redbronco2
Rough Idle
MartinTravels
May 31, 2014 06:52 AM
steveamann
Jul 30, 2013 03:17 PM
Ruckerboy21
Modular V8 (4.6L, 5.4L)
May 26, 2007 12:58 AM
KLINE925
Feb 19, 2006 10:06 PM
atlcatdaddy
Oct 28, 2003 08:20 AM
