80 302 Not Charging
Old Oct 6, 2004 | 07:15 PM
Garret's Avatar
Garret
80 302 Not Charging
Okay I got an 83 Ranger with a 302/C4 combo out of an 80 granada. My problem is that the battery does not get charged by the alternator. I do believe i have the alternator hooked up properly. It is being ran by a voltage regulator but I suspect I may have either hooked up the voltage regulator wrong or I have hooked up the alternator wrong. Can you guys point me in the right direction for getting this thing fixed?
Old Oct 6, 2004 | 07:31 PM
trike1946's Avatar
trike1946
Welcome to FTE Garret. I would probably take the alternator out and get it tested at Pep Boys, AZ etc. Was it working in the granada? If it checks out ok, check your wiring again, and I think I would then replace the regulator. Make sure all your contacts are clean, the cables are clean, and grounds are tight. Electrical problems drive me nuts, so I wish you good luck.
Old Oct 6, 2004 | 07:47 PM
Franklin2's Avatar
Franklin2
I would guess the granada probably had an idiot light. Your truck may have had an amp guage. I would wire it according to what the truck had. Here's the two different diagrams.
With factory amp guage
With factory idiot light
rdnhood
Jun 6, 2010 08:50 PM
BigJake86
Apr 9, 2009 10:39 PM
yukgoon
Apr 5, 2009 03:42 PM
jimbo81587
Electrical Systems/Wiring
Nov 18, 2004 02:32 PM
gmancan
May 11, 2003 07:38 PM
