hard to say. its possible that you may have lost some oil pressure around that rpm and got some piston slap? maybe smacked a valve? hard to say. did the knock go away after bringin it back down in rpms?
Yeah it did. Actually I did a test today and revved the engine to 5000 rpms with the clutch in, with the clutch out and in neutral, and then in first gear and second gear and had no knock. I don't know why, but it only happens at that rpm on that road b/c when I went down that road again (the road to work ) I had the same problem. I'm gonna change my oil this weekend and see what comes out. I changed it two months ago ( 1000 miles.) I'm gonna put some 10-40 in it and maybe a littel type F trans fluid to clean the engine a bit better.
