Charging system trouble? Can you help?
Old Oct 5, 2004 | 11:39 PM
sagesunrise's Avatar
sagesunrise
I have a 1975 F250 390. I first noticed one of the gas tank meters go to zero. I decided to check my blinkers (had headlights and heater on) and the blinkers were very VERY slow. Turned off lights and heater and they speeded up. All the while, there was no drag on the engine. Battery tested good. Any suggestions from you electrical wizards?
Old Oct 5, 2004 | 11:46 PM
olfordsnstone's Avatar
olfordsnstone
alternator, voltage regulator?
Old Oct 5, 2004 | 11:49 PM
sagesunrise
Thanks for your reply. When the voltage regulator starts to go does it perform intermittantly like that? Today I drove the rig with no problems at all. Is there a way to test before replacing?
Old Oct 6, 2004 | 03:01 AM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to electrical systems forum.
The usual problem in old vehicles is bad grounds. Check your engine, body, and frame grounds. If you have much rust on the truck your body ground path may be bad also.
Kris with a K
Feb 24, 2017 03:09 PM
tufftruck
Nov 10, 2016 12:54 PM
v2addict
Apr 11, 2016 09:03 PM
orion39
Oct 2, 2007 05:37 AM
