Bronco II Ford Bronco II
Fuel pump relay?
Old Jul 19, 2001 | 11:06 AM
loudfords's Avatar
loudfords
Fuel pump relay?
I drove my 87 Bronco II thru the creek a couple times on the weekend (not very deep) and it quit running. I'm thinking it's a fuel pump relay because when you turn on the ignition I can not hear the fuel pump priming at all. All the wiring to the pump & tank is ok. The emergency impact shutoff was not tripped at all. Is it possibly the fuel pump relay? How can I tell? Is this one of the 3 relays on the passenger side fender?
Thanks for any help.
1979 F150 Custom: nothing under the hood at all (again)
1987 F150 XLT Lariat: 88 351W EFI
84 351W: soon to have 91 heads, Crane PowerMax cam, double roller timing chain, Edelbrock Performer intake & Holley carb and be put back in 79 F150
86 & 87 Bronco II: next winter's beater
Old Jul 20, 2001 | 01:22 AM
babybroncoii's Avatar
babybroncoii
Fuel pump relay?
i don't know if this is your problem but it is the green relay in the same spot you are talking about. a new relay is only a few dollars so why not replace in anyways
Old Jul 20, 2001 | 08:42 PM
loudfords's Avatar
loudfords
Fuel pump relay?
Thanks for the help. I think I'll try it tonight yet. And cheaper than a few dollars is getting the relay out of the other Bronco.
Old Jul 20, 2001 | 10:06 PM
1986broncho2gal's Avatar
1986broncho2gal
Fuel pump relay?
On the fuel rail that hooks to all the fuel injectors, to find out if your pump isn't pumping up, there's a thing like an air valve for your tire. Turn the ignition on and depress the shrader valve. If fuel spews out, you're getting pressure. If fuel spews out and it's still not starting, look elsewhere...spark plugs or no juice to the injectors.
Old Jul 24, 2001 | 08:29 PM
loudfords's Avatar
loudfords
Fuel pump relay?
Ok, I have a fuel problem. It isn't the pump, the relay, or the shutoff switch, all were bypassed or replaced. Any other places to check? Fusible links or anything? Is the fuel pump relay signalled by the computer? I pulled back the carpet and there was a huge gap where the firewall used to meet the floor pan and the carpet was all wet there. I didn't fry my computer by some freak chance, did I?
The only good side to not having a running 2.9 to get the Bronco on the road is another "pro" to installing a 5.0 :-)
84 351W: soon to have 91 heads, Crane PowerMax cam, double roller timing chain, Edelbrock Performer intake & Holley carb and be put back in 79 F150 next week?
Old Jul 24, 2001 | 11:56 PM
1911bronco's Avatar
1911bronco
Fuel pump relay?
bill1wts
Aug 12, 2012 01:33 PM
Spook10165
Bronco II
Dec 4, 2006 05:33 AM
wakojoe
Dec 7, 2005 11:28 PM
kittkatt
Bronco II
Dec 20, 2004 05:31 AM
gaknut
Aug 13, 2004 05:16 PM
