Oxygen sensor
Old Oct 5, 2004 | 04:18 PM
1991_DkBL_FordRanger's Avatar
Oxygen sensor
How many oxygen sensors does the 3.0L v6 have in the 1991 ford ranger?
Old Oct 7, 2004 | 10:10 PM
silvapain's Avatar
silvapain
Look just below the exhaust manifolds. There will be a cylinder threaded into a boss just below the manifolds - that's the HO2S sensor.
I would guess two sensors for your year, but I'm not sure. Newer OBDII vehicles have four.
Old Oct 8, 2004 | 01:19 AM
hood's Avatar
hood
I believe that there is just one. I replaced mine a few years back in my '91 ranger. Wasn't the easiest thing to get to, but with patience you can do it.
I remember tieing a length of string to the harness that went to the O2 sensor to keep it from falling into unreacheable crevices. Believe me, the string thing did help. Good luck...may the ford's be with you!
I have 158,000 miles on my '91 and get about 21-23 mpg.
-hooD
Old Oct 8, 2004 | 01:31 AM
hood's Avatar
hood
It was the harness that i kept tied up so it was easy to retrieve once the sensor was removed. There is not alot of length to the harness, so once you remove it from the sensor you will have a hard time getting it back into reach.
The string allowed me to let the harness fall where it wanted and then be able to pull it back into reach when the sensor was installed.
-hooD
Old Oct 19, 2004 | 09:49 AM
thanks guys i used a bungee cord becuase the old one got stuck when i was trying to pull it out. It runs much nicer now
Easytime
Jun 23, 2013 09:37 PM
chip.carden
Aug 10, 2011 07:57 AM
75250ranger
Aug 29, 2010 09:37 PM
Ultramagdan
1997 - 2003 F150
23
Jan 18, 2009 07:23 PM
capstan
Apr 14, 2005 08:02 AM
