stearing problem
Old Oct 7, 2004 | 02:40 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
When I get time tonight I will see if is to big to post,,,if not....well
Old Oct 7, 2004 | 04:36 PM
SBV45's Avatar
SBV45
I can only export it from the service manual to pdf. You can download Acrobat Reader from Adobe. It is a freebie. Then print it out.
Old Oct 7, 2004 | 06:40 PM
X 03 Jeff's Avatar
X 03 Jeff
Im sorry, I might be confused but I do have Arobat Reader on my computer.
Im not sure what you need me to do, in order to recieve it. Please let me know.
Thanks
Jeff
Old Oct 7, 2004 | 06:50 PM
SBV45's Avatar
SBV45
Send me an email and I will reply. I sent you a private message.
Old Oct 7, 2004 | 07:01 PM
X 03 Jeff's Avatar
X 03 Jeff
Sorry for the confusion, I dont know your e-mail so i just sent you a private message.
Jeff
Old Oct 7, 2004 | 07:03 PM
SBV45's Avatar
SBV45
Got it. You should have both the adjustment document and the diagnosis document on your email. The files aren't too big in case you are on dialup.
Old Oct 7, 2004 | 07:17 PM
X 03 Jeff's Avatar
X 03 Jeff
I would like to say a big thank you to all .
It may take me a few to figure all of this site out, but you all seem to be good people which make it a pleasure.
When I get back from the dealer tommrow I will let you know the outcome.
But again THANK YOU !!!
Jeff
Old Oct 7, 2004 | 07:20 PM
X 03 Jeff's Avatar
X 03 Jeff
got it all thanks so much,
Jeff
Old Oct 7, 2004 | 07:36 PM
SBV45's Avatar
SBV45
Welcome, this is what FTE is all about.
Old Oct 8, 2004 | 11:31 PM
X 03 Jeff's Avatar
X 03 Jeff
Hello all,
Well should I be suprised confused or mad ? How about shocked, Im just in disbelief and not sure of what to do.
I got to the dealership this morn, with adjustment documents in hand, and explained to the service advisor and mechanic that the adjustment that they did a day or to before was not like what these documents explained as proper.
I also said that if they did this adjustment as per the instruction, that there may not be a need to replace the gear box.
They listen to me and decided that the gear box was bad and decided to go ahead and replace it with out the attempt of proper adjustment.
Well I picked up my X late today with the new gear box installed. And discoverd on my way home that my steering wheel is now of center and the play in my steering wheel is the same with the new gear box if not worse.
I called when I got home and they said that they would straighten the wheel on monday, I can only hope that they will attempt to adjust the new gear box.
Im just wandering if I should just losen the lock nut and adjust the set screw only, on my own ?
I dont have the tools or know how to do the complete procedure on my own, especailly trying to take out the airbag.
Do you think that, this would mess something up within the new gear box, or possibly something else ? Give me your thoughts if you dont mind.
Thanks much
X 03 Jeff
Larry Grimes
Oct 15, 2013 08:13 PM
cOpE!
1978 - 1996 Big Bronco
Mar 11, 2010 07:22 PM
78longbed
Jul 14, 2008 04:41 PM
tinsmith
Apr 26, 2004 09:01 PM
AK77
May 6, 2002 12:59 PM
