Bronco II Ford Bronco II
Advice on BII's
Old Mar 10, 2001 | 04:04 PM
tcbradbury98's Avatar
tcbradbury98
Advice on BII's
I just bought an 87 bronco 2 and I would like to know what I can do to make it sway less, lowering is out so, is there some way to widen the wheelbase? Also where can I get a rear spare tire carrier to bolt onto the back as the one on mine is missing? Tried salvage yards and lucked out. Where can I get the best manual for my BII?
Thanks, TC.
Old Mar 10, 2001 | 10:18 PM
pee wee's Avatar
pee wee
Advice on BII's
I do not know about the first two questions but the manual I would not get a Chiltons I just got one and it pretty much sucks in my opinion. The spare tire carrier I would keep trying the salvage yards, around here where I live Bronco II's are a dime a dozen in most salvage yards.
Old Mar 11, 2001 | 12:41 AM
blacklightningf150's Avatar
blacklightningf150
Advice on BII's
Well to help the sway you can get new shocks, and or for better stability an offset rim so that the tires stick out more is good to. As for the rear tire rack keep lookin theres alot out there, the manual chiltons is a good manual but it does leave out some of the basics but for "non-major" work its great.
Hope this helped
2000 F150 Extended Cab 4x4 Sport "Black"
Head light covers
Tail light covers
"FordmotorSports" sticker in rear window
Stereo upgrade soon need some "thump"
Old Mar 11, 2001 | 09:49 AM
tcbradbury98
Advice on BII's
Thanks for the advice. Is there a place to get an original manual?
Old Mar 11, 2001 | 11:54 AM
blacklightningf150
Advice on BII's
Id say the dealer would be the best place..... might cost more but it would be original
2000 F150 Extended Cab 4x4 Sport all Black
Headlight covers
Tail light covers
"FordmotorSports" Sticker in rear window
Old Mar 14, 2001 | 11:07 PM
rcriverclub's Avatar
rcriverclub
Advice on BII's
ebay has a tire carrier for bid right now. hanes manuals too. Chiltons are there too but not worth the $.
Old Mar 15, 2001 | 08:12 AM
Avanti's Avatar
Avanti
Advice on BII's
On the spair tire carrier. Some Bronco II came with out them . Check to see if the slots on the door frame are there for the bracket. I have an 89 Bronco II with the rear carrier & my son has an 88 with out. We compared the two when he was looking for a carrier for his. A little info.
89 Bronco II XLT
92 F150 XLT ext cab
93 Aerostar AWD
Old Aug 1, 2001 | 12:12 AM
broncoIIGT's Avatar
broncoIIGT
Advice on BII's
sway bars and double shock mounts ..
go to jamesduff.com
Old Aug 1, 2001 | 10:01 PM
77_F150_4x4's Avatar
77_F150_4x4
Advice on BII's
To get rid of the sway you have some choices K bars S makes dual front shock hoop. You can use the stock shock mount location with and make it a triple shock, plus its only $70 compared to James Duff $125, but this will make the front end a lot stiffer some say it is overkill. For the rear Roadmaster Active Suspension will stiffen up the rear end or you could go with leaf springs off a newer explorer they will fit.
Curtis
77_F150_4x4 aka "The BeAsT"
85 Bronco II XLT 2.8L 4x4 auto
Old Aug 4, 2001 | 06:09 PM
kaptain's Avatar
kaptain
Advice on BII's
Try getting some new bushings for the front sway bar, and even in the back as well.. It's a realy inexpensive option, and i just put new ones up front, there's alot of improvement.
Old Aug 8, 2001 | 08:59 PM
Biggins's Avatar
Biggins
Advice on BII's
Shanook9080
Bronco II
May 19, 2014 02:46 PM
yyyames
Bronco II
Jul 31, 2012 09:53 PM
kwolfx3
Bronco II
Jan 22, 2009 07:22 AM
Cravin
Bronco II
Oct 11, 2006 03:06 PM
lakahahahman
Bronco II
Sep 9, 2003 06:45 PM
