upper control arms
upper control arms
I need to replace the upper control arms on my 2000 expy 2wd. Anyone do this before and have any tips etc. My chiltons book just says upper arm/ball joint serviced as a unit but does not give any info on how to do it. Also any info on cam/bolt kits for the upper arm??? Thanks cajunbull61
Initially I would suggest going to the parts counter at Ford and ask for an exploded view of that area. Then ask them about the cam kit.
Just curious, why do you need to replace the upper arms? I recently just had my bushings done at 325k, nothing else, are your ball joints bad?
My Haynes book shows a pretty fair breakdown procedure with pics on the cam kit and arm removal, can be picked up for about $11 at any parts store.
The ball joints are/were shot. I replaced the uppers and lower joints with Moog parts. The uppers are now replaceable with out changing the control arm. I did get the Moog camber kits as well. The cost was about 280.00 for parts. It wasn't as hard as I thought it might be. A few hours work except for putting the upper arms on the wrong sides. That cost me some extra time and embarrasment. Such is life.
AKSTAR
Aerostar
15
May 27, 2006 06:11 PM
cajunbull61
Dec 24, 2003 12:04 AM
cajunbull61
Jul 30, 2002 09:13 AM
