Engine Placement
Old Oct 4, 2004 | 08:45 PM
56dog1's Avatar
56dog1
Engine Placement
I need to know how far back to mount my 351 Cleveland with C6 transmission in a 56. Mid Fifty says about 34 3/4" from center of cross member to front of frame for small block. Is this right?
Also, do I need special quality bolts to mount the pads to the crossmember?
Old Oct 5, 2004 | 06:45 AM
mt54's Avatar
mt54
What works best is to mock it up with the rad. Rad. clearence is the biggest concern.
It will depend on what type of fan your useing. With that in mind place it where it needs to be, then you may have to mod the fire wall for clearence.
Mike
Old Oct 5, 2004 | 07:11 AM
merc546's Avatar
merc546
If you want to be sure that the eng/trans fits you will need to have the rad installed and the cab in place. Mt54 is right about the fan issue.
If you are going to use a mech fan keep at least 1-2 inchs clearance to the rad.
You will not have a package problem with your eng/trans selection just make sure if you have a firewall mounted brake booster that you can remove the rocker arm cover.
I have done a 351W/C6 and a 351W/FMX/AOD (changed trans) both in 56's booster was one of the main package concerns for me.
Chuck
Old Oct 5, 2004 | 08:44 AM
Randy Jack's Avatar
Randy Jack
I have a 351C/FMX in my 56. I run an electric fan now, but it came with a mechanical fan and shroud. Mike (MT54) is right on about positioning. LOTS of room around it with no firewall mods required. In fact, there is a fist-sized clearance between the heads and bell housing to the firewall/cab floor.
Forward/aft positioning is very forgiving. I would only caution about setting the engine height in the compartment. Make sure you can get the pan off without pulling the motor. It will also look better if it sits higher. Doesn't get lost down in that big hole.
Old Oct 5, 2004 | 02:30 PM
56dog1's Avatar
56dog1
Good Advice
Thanks for the information. I'll mount the radiator and get the engine and transmission in. I'm am worried about what too deep means. I do want to have my brake assembly clear the valve cover. I had this problem with a 56 with a 428.
Old Oct 5, 2004 | 08:19 PM
husker's Avatar
husker
56, I mounted a 460 in a '54 with a c6 behind it . I used the bolt in or weld in mounts from one of the suppliers of older Ford truck stuff, Can't remember which one maybe Bob's F100s. I also mocked the engine in before welding in the mounts. I move the engine as far back as I could with about 1" clearance from the valve covers etc. I mounted the engine high to get a proper angle for the drive shaft and still clear the floor of the cab. I run a fan and have a couple of inches from fan to radiator.
Old Oct 6, 2004 | 01:20 PM
51dueller's Avatar
51dueller
It's better to have the exhaust manifolds bolted to the engine when your mounting so you don't have to try many different headers to get some that fit.
Old Oct 6, 2004 | 07:23 PM
56dog1's Avatar
56dog1
headers?
I have not got around to buying headers for the 351 yet. Any suggestions?
dadz34
Oct 29, 2013 09:07 PM
WALFORD'S 56
Nov 1, 2008 06:18 PM
jack71
Nov 9, 2007 10:17 PM
ferguson777
Jun 19, 2005 05:40 PM
F100man
Dec 10, 2004 05:41 AM
