Explorere Stalls on start up
Old Oct 4, 2004 | 12:10 PM
Fordfanz's Avatar
Fordfanz
Ok in the morning or when the motor is cold and my wife starts it it stalls like its out of Fuel crank it again and as long as you dont let off the gas it runs but let off the gas and it stalls .Once it warms up its fine but for about 5 minutes it wont idle
Is it a fuel filter Or wha t ?
thanks Fordfanz
Old Oct 4, 2004 | 12:24 PM
marragtop's Avatar
marragtop
It could be the IAC. Check the sticky at the top of the forum for more info.
Mike
Old Oct 4, 2004 | 12:42 PM
Fordfanz's Avatar
Fordfanz
woo should have looked up there first
thanks marragtop for the info
fordfanz
Old Oct 4, 2004 | 02:44 PM
missviv2's Avatar
missviv2
Even if you had a voltage meter, it is probably best if you replace the IAC valve. It is usually a $50 part on an Explorer. It will save you in the end. Suppose you test it, and tests show it's OK. You clean it and put it back on. It runs great for a while and then all of a sudden it konks out on your wife when she least expects it. Save yourself a headache, get a new one, put it on in 5 minutes and be done with it for 100,000 miles or more (that's how long my first IAC valve lasted).
joshofalltrades
Mar 7, 2013 02:27 AM
Fordfanz
1997 - 2003 F150
May 27, 2012 05:42 PM
Fordfanz
Aug 15, 2009 06:36 PM
Fordfanz
Nov 24, 2005 07:28 PM
Fordfanz
20
Oct 20, 2004 08:07 AM
