Oil Dip Stick
Old Oct 3, 2004 | 03:14 AM
Vinheyhey's Avatar
Vinheyhey
Oil Dip Stick
Hi All ,
Went for my first oil change at the ford dealer , seem's they put a used oil dip stick back in the engine ?? If someone with a 04 5.4 can measure from top to tip and post for me would help me to go back and bitch about it.
Thanks for the help !
Vinnie M.
Old Oct 3, 2004 | 10:09 AM
79REK's Avatar
79REK
Originally Posted by Vinheyhey
Hi All ,
Vinnie M.
Mine is 27 3/8 from the tip of the stick to the center of the o-ring. There is what looks like a part number just above the full mark. It is 3L3E-6750-DA. Hope this helps.
Old Oct 3, 2004 | 04:07 PM
Vinheyhey's Avatar
Vinheyhey
Oil Dip Stick
Thanks 79Rek ,
Will go out and check , will post for ya , yes just the info i need .
Thanks Vinnie M.
Old Oct 3, 2004 | 06:40 PM
Dunk's Avatar
Dunk
Speaking of Dip Sticks.... Has anyone noticed we have two piece dip sticks?? What up with that?? Rivots?? They couldn't find enough steel that long to make them one piece.. Probably tripled the cost to make them...
Old Oct 4, 2004 | 01:02 AM
Vinheyhey's Avatar
Vinheyhey
Wrong Size
Hi 79Rex ,
Ok was wrong size , only got 27" and also i do remember from Dunk's post reply that there was rivits on the stick when it was new ?? Means i have to much oil in the engine because it reads full , cute on there part i never did nothing to them { THE DEALER } . Will go back with the specks that 79Rek gave me and let them do it over with me standing there this time .
Thanks Men !
Vinnie M.
Automotive Recalls and Technical Service Bulletins for 2004 Ford Truck F 150 4WD Pickup V8-330 5.4L SOHC VIN 5 SFI.
<CENTER>Provided by ALLDATA
<!-- begin ads --><!--begin ads --><TABLE cellPadding=3 width=500 align=center border=0><TBODY><TR><TD bgColor=#ffffff>
</NOSCRIPT>
</TD></TR></TBODY></TABLE><!-- end ads -->
<CENTER>Service Bulletins</CENTER></CENTER>
TSB Number Issue Date TSB Title
  1. 04-8-3 MAY 04 Electrical - Correct Wire Splicing Procedure
  2. 04-7-1 APR 04 Parking Assist System - False Activation
  3. 04-3-3 FEB 04 Drivetrain - Vibration at Highway Speeds
  4. 04-2-6 FEB 04 Body - Power Sliding Back Glass Squeaks/Rattles
  5. 04-2-5 FEB 04 Body/Cooling - Radiator Core Support Service Precautions
  6. 04-1-6 JAN 04 Driveline - Clunking/Grunting Noise/Shudder
  7. 03-26-4 JAN 04 Body - Rear Door Wavy Appearance/Rattles
  8. 03-23-5 NOV 03 Body - Bed Extender Component Replacement Tips
  9. 03-23-2 NOV 03 Body - Exterior Mirror Glass/Motor Service Tips
  10. 03-22-4 NOV 03 Wheels - Correct Lug Nut Torque Specifications
  11. 03-20-4 OCT 03 Body - Unable to Open Doors With Inside Door Handle
  12. 03-20-8 OCT 03 Steering - Steering Wheel Nibble Above 60 Mph
  13. 03-18-1 SEP 03 Keyless Entry System - Service Tips
  14. 03-10-5 MAY 03 Electrical - Wiring Harness Replacement Tips
</PRE>
Old Oct 4, 2004 | 06:10 AM
lardman's Avatar
lardman
The company probably uses the same top piece for both the 5.4 and 4.6 l engines but have different length bottom pieces for each engine. A lot cheeper than making 2 separate dip sticks.
Amicus
Jul 31, 2015 09:10 AM
Johnny Be Cool
Jan 29, 2015 12:16 AM
mkrog
Apr 12, 2012 10:56 AM
Nincompoop
1997 - 2003 F150
Dec 22, 2011 10:20 AM
ADL
Jun 8, 2007 03:54 AM
