Bronco II Ford Bronco II
Low idle bad
Old Nov 8, 2001 | 10:49 PM
Stone_Cold_Crazy's Avatar
Stone_Cold_Crazy
Low idle bad
I just bought a bronco II it dies on low idle when cold and sputters on low idle when hot sometimes it starts to sputter when im driving like its out of gas but it isnt... it starts to sputter then kinda dies (while im on the road) then when it dies for a sec it will pull the gas pedal to the floor the it just starts up again it only sputters for a sec I tried setting the low idle no luck i dont know what to do and i cant afford 80 bucks an hour for someone to poke it with a stick till they guess whats wrong with it its an 85 bronco II 2.8 litre carb auto
body is good 4x4 is good shocks and suspension is good interior is great just put a sony deck and amp and sub in back so i dont wanna scrap it maybe i will do the 4.0 thing cant afford the 5.0 thing though please any help is much appreciated
Old Nov 9, 2001 | 07:18 PM
steve_'s Avatar
steve_
Low idle bad
hmmmm sounds like you some vaccume issues id start with the egr valve. does it pop when going down the road? kinda like cut out almost constantly? there are things you can do without the help of a mechanic id check all the vaccume lines and make sure they are all connected or not broken, make sure they are all going to the right places etc... if you have a multi meter and a repair manual it will tell you how to check elec curcuits. id hate to use my old 85 bronco2 as an example as it was just a nightmare of a vehicle. that was due to the mechanics that rebuilt the motor. instead of disconecting wires at their point of origin they just cut them all in half and then spliced them after. but defiantly give the engine compartment a good looking at and you may find a broken vaccume line. howver it really almost sounds like a bad egr valve or at least the sensor that goes to it not much that can actually go wrong with an egr valve it either works or it doesnt but if the sensor isnt teling it to open or close at the right time then that could cause haywire to happen. good luck with it hopw you have better luck with your 85 than i had with mine
Old Nov 11, 2001 | 06:52 PM
steve_'s Avatar
steve_
Low idle bad
dencrawford
1983 - 2012 Ranger & B-Series
May 2, 2012 11:05 AM
dencrawford
Bronco II
May 1, 2012 06:01 PM
agg_bagg
Jan 10, 2011 01:44 PM
Hmann
Mar 9, 2010 09:23 PM
Drgslayr
Jul 16, 2009 02:49 PM
