87 Bronco II - Random Sputtering
Old May 2, 2012 | 08:22 AM
dencrawford's Avatar
dencrawford
I have the 87 Bronco II 2.9 L. The truck idles fine, while in park or neutral, if you step on the gas the RPM's run right up with no hesitation. (Both fuel pumps and filter are new) but randomly when you are driving it sputters like it is not getting gas. If you pump the gas pedal it will keep sputtering but never actual dies. Speeds continue to increase but constant hesitation. Park it and there is a 50/50 chance it will run fine next time or do the same. The last 4 times out the first 3 times ran like a charm, then the 4th time starting sputtering again. Any ideas?
Old May 2, 2012 | 11:05 AM
MisterRanger's Avatar
MisterRanger
Maybe the sparkplugs?
kristinaleacisneros
1978 - 1996 Big Bronco
Jul 8, 2015 12:08 PM
Jessie Castonguay
Bronco II
May 23, 2013 08:46 PM
dencrawford
Bronco II
May 1, 2012 06:01 PM
FreeAgentRider6
May 21, 2004 03:21 PM
gtb121874
Bronco II
Jun 3, 2001 10:50 AM
