Bronco II Ford Bronco II
86 B2 tranny HELP!!! please!
Old Dec 18, 2001 | 10:48 PM
nytemare1's Avatar
nytemare1
Hi,
Just found your site & need major help. My 5 speed mitzu tranny has locked up, i think. Will move between 3rd. & 4th. but does not seem to fully engage. If I put it where neutral should be, & let out the clutch it will take off like it is on 1st. But trying to get in another gear is impossible. No matter where I try to move the shifter it will still take off like it is still in 1st. As I am not that mechanically inclined as far as trannys go any suggestions as to what might be causing this would be greatly appreciated. This is a 4x4. If all else fails could someone tell which other transmissions would fit so when looking through ads I wont just look for 86 B2 trannys.
P.S.-I have an 85 B2 I bought for leeching off of with a perfectly good(unfotunately a mazda tranny)or is there a way to modify or add adapters or anything to make this one fit?
Thanks for any & all help people.
Old Dec 19, 2001 | 11:08 AM
Avanti's Avatar
Avanti
It sounds like the hydraulic clutch. It maybe leaking, check for fluid loss. If fluid is down it is a leak and you need to rebuild or replace it. After replacing it, the air needs to be bled out of the system.
Old Dec 19, 2001 | 02:43 PM
nytemare1's Avatar
nytemare1
Post 86 B2 tranny HELP!!! please!
Thanks for the clue. Have not noticed any leaking but I just bought this and it may have been so low that it was just a matter of time. Would you know the answer to my P.S.??
Old Dec 19, 2001 | 03:14 PM
Avanti's Avatar
Avanti
Sorry do not have an answer for your PS. Do some searches on this site and also call a local wrecking yard and ask them to check in their Hollander intertchange book. Ask them what transmissions will interchange with yours.:-)
Old Dec 20, 2001 | 01:04 PM
josh3972's Avatar
josh3972
you can try http://www.advanceadapters.com for the transmisson adapters:-X12
Old Dec 20, 2001 | 01:38 PM
nytemare1's Avatar
nytemare1
Thanks for the link Josh!
Old Dec 20, 2001 | 06:02 PM
ShallowGrave's Avatar
ShallowGrave
dunecj2a
Jan 3, 2013 06:09 PM
IDIDieselJohn
Sep 7, 2011 01:11 PM
tbone681
Oct 25, 2010 03:20 PM
girlwithatruck
103
Apr 11, 2010 09:16 AM
Q's 86
Aug 20, 2008 07:53 PM
