Removing Aftermarket window tints
Old Oct 1, 2004 | 12:15 PM
Dragrazor's Avatar
Dragrazor
My Window tint film is old and purple and I want to remove it. I peeled off a vent window with much difficulty and now I have alot of glue left on the glass. It's not sticky but it's "on there."
What is the easiest way to remove the rest of it since I have an X-cab with sliding rear windows!
Old Oct 2, 2004 | 01:02 PM
Lesspaul's Avatar
Lesspaul
Use soap and water,the same solution use to apply the film (5 drops of dish soap to a pint of water) spray it on and scrape it with a new razor blade. Let it soak if it does not come off easy, but it should come right off with ease.
Old Oct 2, 2004 | 02:03 PM
RyanF's Avatar
RyanF
I have also used just regular window cleaner when it is not sticky with a razor blade.
Old Oct 4, 2004 | 02:32 PM
Smaug's Avatar
Smaug
glass cleaner, Goo Gone, fingernail polish remover w/ acetone
Old Oct 4, 2004 | 04:13 PM
kingfish51's Avatar
kingfish51
I have also seen products to use to remove the film and glue. I saw some at Walmart the other day. Small bottles. I have used this type of product for film on my homes windows. Got that product at Lowes. Same section as the window tints. This was larger spray bottles.
Old Oct 4, 2004 | 07:32 PM
Dragrazor's Avatar
Dragrazor
Thanks, I did it today and used an old spray bottle with water and dishwashing soap. I sprayed and scrapped with some razor blades and got them all off. Not as bad as thought it would have been. I did however cut myself pretty good! Wow, I'm a bleeder!
Old Oct 6, 2004 | 10:54 PM
kedwinh's Avatar
kedwinh
Talking
Just remember next time, the sharp end goes toward the glass...
gregj
Paint & Bodywork
23
Jan 20, 2014 07:58 AM
jonnykford
1978 - 1996 Big Bronco
Apr 8, 2011 07:10 PM
Monty06
Appearance & Dress-Up
Mar 4, 2005 12:24 AM
MemOrex
Aug 6, 2004 02:46 PM
dynocompe
18
Jul 31, 2004 12:47 PM
