Oil Change Question
Old Oct 1, 2004 | 11:48 AM
stephj1's Avatar
stephj1
Question Oil Change Question
I recently purchased a 2000 F-250 7.3L Turbo Diesel and I usually do all my own oil changes. Quick questions: After refilling the engine oil, is there any additional procedure that should be followed to make sure the turbo has sufficient lubrication prior to starting the engine for the first time?? Does draining the engine oil also drain the oil supply to the turbo charger??
Thanks in advance...
Old Oct 1, 2004 | 12:46 PM
99PSDCREW's Avatar
99PSDCREW
I suggest prefilling the oil filter before starting so that the muffler bearings get lubricated quicker, I heard you don't want those to go out.
Old Oct 1, 2004 | 01:23 PM
Ggg6's Avatar
Ggg6
Nothing special, just fill it and the filter up and start. Use a 5gal capicity drain pan. Poke a hole in the filter before loosening it, so it will drain out. Because it holds a lot of oil.You can get the Motorcraft brand filters at Wally world about $10.
Old Oct 1, 2004 | 01:26 PM
basstardo's Avatar
basstardo
No, there is oil in the upper parts of the motor that will not drain out. Places like the turbo, HPOP, and around the injectors I believe.
Old Oct 4, 2004 | 10:57 AM
Silverrv's Avatar
Silverrv
If you have any concerns about problems related to the oil change have the oil tested. I only costs $20.00 and is well worth it..
Old Oct 4, 2004 | 10:06 PM
rmilchman's Avatar
rmilchman
Loosen the filter first, then poke a hole. If you poke the hole first and the filter is over tightened it will crush. Leaving the oil in it help prevent the problem.
alvald83
Oct 5, 2012 11:35 PM
mtnxtreme800
Dec 24, 2011 05:50 PM
wedge88
Crossovers
Feb 14, 2009 07:35 AM
Joker50
Feb 10, 2008 08:08 PM
ssKable
1997 - 2003 F150
16
Feb 3, 2005 10:48 PM
