Sponsored by: Real Truck
Disable rear sensor for entire engine cycle
Old Sep 30, 2004 | 06:32 PM
jdadamsjr's Avatar
jdadamsjr
Did u know the dealer can reset your rear sensors to only be reactivated with a key cycle, not every time it goes into reverse ?
bring this to them and it's quick :
Special Service Message # 17815 - MULTIPLE VEHICLES -- PROCEDURE TO DISABLE REVERSE SENSING SYSTEM (RSS) FOR ENTIRE IGNITION CYCLE - SERVICE TIP.
To program the reverse sensing system (RSS) switch so it will disable the RSS system for the entire ignition cycle, rather than turning back on each time the transmission is put into reverse, Perform the following using the NGS service card (Green Card) Level 10 or higher
1 Select service bay functions
2 select PAM module
3 Select module option content (Hit Trigger)
4 Select Vehicle (Hit Trigger)
5 Hit trigger to highlight IGN or REV
6 Scroll to toggle between IGN or REV (Hit Trigger)
7 Select done which is soft key #8 (Programming Should Now Be Complete)
Effective Date 05/20/04
Old Sep 30, 2004 | 08:39 PM
n6nfg's Avatar
n6nfg
Wow, if this is true it will make my very happy. There was talk of the July 04 flash as modifiying this behavior in an earlier thread, but it didn't seem to do it for me. I am going in for service in 2 weeks, I will definately persue this.
Thanks for the tip, and hope it works.
Old Sep 30, 2004 | 08:51 PM
Y2K350's Avatar
Y2K350
I'm confused, or actually ignorant.
What is the rear sensor and what does it do?
Old Sep 30, 2004 | 09:21 PM
n6nfg's Avatar
n6nfg
It is the sensors mounted on the rear bumper that warn you when you are getting close to something. It is an option, not part of any standard package.
When you are towing a trailer, everytime you go into reverse, the system detects your trailer and starts beeping at you. Very annoying when you are trying to backup to park.
Old Sep 30, 2004 | 09:26 PM
Y2K350's Avatar
Y2K350
Thank you for the education. I learned something new today.
Old Sep 30, 2004 | 10:47 PM
s2gots's Avatar
s2gots
why cant you just hit the off button????
Old Sep 30, 2004 | 11:10 PM
PowerStroke King's Avatar
PowerStroke King
I can disable my rear-sensor with the button they provide to turn it off. It's much easier.
Old Sep 30, 2004 | 11:50 PM
n6nfg's Avatar
n6nfg
Thats the whole point of the change, to make the "off" button stay set off until the ignition key is cycled again. When you are parking a large trailer, you often have to cycle between forward and backward several times to get the trailer positioned correctly. With the default button behavior, everytime to turn it off, it only stays off till you put the transmission into forward. Once you go back into reverse, the sensor turns back on. So every time you go from forward to reverse, you have to hit the off button. This is what is annoying. If you could turn it off ONCE, and have it stay off regardless of what you do with the transmission and direction of movement, then you can ignore it during parking. Once you turn off the engine, it resets to "normal" behavior, I.E. when you shift to reverse, it will be ON again. Make sense?
Old Sep 30, 2004 | 11:52 PM
s2gots's Avatar
s2gots
now it does..!!!!!
Old Oct 1, 2004 | 09:49 AM
R1ZOOM's Avatar
R1ZOOM
good post thanks for the info
Old Oct 1, 2004 | 04:42 PM
jjgi5150's Avatar
jjgi5150
jdad...
Great post! I will be having that done as soon as possible. Towing season is approaching!
Thanks,
JJ
Old Oct 1, 2004 | 08:32 PM
daveplot's Avatar
daveplot
I see this is for "MULTIPLE VEHICLES" does that include the 2003 Expedition?
Old Oct 4, 2004 | 12:03 PM
daveplot's Avatar
daveplot
Can anyone tell me that has had this done, if it's covered by warranty or did you have to pay for it to be done?
Old Oct 4, 2004 | 09:05 PM
RUSH24's Avatar
RUSH24
my 05 stays off until the ignition cycle.
Old Oct 4, 2004 | 11:57 PM
n6nfg's Avatar
n6nfg
I was thinking the exact same thing. Knowing my luck, they will charge me for it, as there is "nothing wrong" to repair under warrenty.
