Foam Sealant
Old Sep 30, 2004 | 02:16 PM
weymouth's Avatar
weymouth
Question Foam Sealant
In the process of repairing the rotted area where my driver’s door pillars meet the rocker panel, I’ve had to scrape away a bunch of flexible gray foam. It looks like it was some sort of filler that was squirted in and allowed to expand and fill the voids.
Before welding in the patches, I plan on soaking all, soon to be enclosed, surfaces with Ospho and giving it a good shot of Rustoleum.
Does anyone have an opinion as to whether it would be a bad idea to, after the welding in of patches, squirt in a bunch of the expanding foam sealant (i.e. “Great Stuff”) to fill the voids and reduce the possibility of moisture building up in this area? I plan to use the type of foam called, “Low expansion, Closed Cell” so it itself, will not tend to absorb moisture.
Old Sep 30, 2004 | 03:09 PM
Mike W's Avatar
Mike W
I originally thought so. I then read something from a guy that replaces a lot of rusty panels. He said not to do it.
Old Sep 30, 2004 | 06:38 PM
peppy's Avatar
peppy
Like you said......Great Stuff. Never used in a car or truck. But all over the house. Expands to a fault sometimes......cuttable, and sandable. Holds pretty well in my experiance.
Old Sep 30, 2004 | 10:16 PM
theologian's Avatar
theologian
I am thinking of using some of that in both my F150, and a trailer that needs the wiring harness protected.
Old Sep 30, 2004 | 11:48 PM
big hoss 29's Avatar
big hoss 29
IIRC: that stuff actually traps moisture in a car or truck. You could go to an autobody supply shop and get an automotive approved sealer, it repels moisture.
CarCrazy1001
Aerostar
Oct 8, 2020 07:08 PM
Russ74
Feb 7, 2017 08:28 AM
05 F150silent inside
2004 - 2008 F150
53
May 15, 2013 08:49 PM
vwhed1979
Aerostar
Mar 28, 2012 09:59 PM
65F1005.8
25
Feb 14, 2011 11:19 PM
