93' - blower/wiper problems
Old Sep 29, 2004 | 06:09 PM
Trigger's F350's Avatar
Trigger's F350
I have a 351/4x4/standard/air. The blower motor only works on hi,,,and the wipers come on when you put the turn signals on. I replaced the blower fan switch and checked the motor. All work. Is there a resistor pack for the voltage drop to the fan that I am missing???
Old Sep 30, 2004 | 10:00 AM
TMF's Avatar
TMF
I had a similar problem on my '94 F-350 and the turn signal nonsense went away with a new flasher. As for the blower, it sounds like there is a bad connection somewhere, probably nearer the motor as you already replaced the switch.
My '94 F-350 is currently only letting air vent upwards (defrost) regardless of where the setting is. Anyone know where a map of the vacuum lines can be found so I can trace possible vacuum line issues? My Haynes manual doesn't have one.
Thanks!
Old Oct 1, 2004 | 06:25 AM
MustangGT221's Avatar
MustangGT221
To all users, please make titles to threads that accurately depick the subject matter
Old Oct 1, 2004 | 01:42 PM
the other Alex's Avatar
the other Alex
Blower Problem
I fixed this on my '93 F250 last night.
There is a resistor next to the fan motor on mine (no A/C).
Ford P/N E9TZ*19A706*A - $12.70.
PIA to get the pigtail off, but after that a 5 minute job.
Old Oct 1, 2004 | 06:06 PM
jamiesan's Avatar
jamiesan
Try cleaning the conections for the motor, particularly the ground, steel wool & electra-clean do nicely!
Old Oct 1, 2004 | 08:08 PM
Trigger's F350
Thanks for the help. I'll try these soon!!
Trigger
Super Econoline
17
May 18, 2013 08:34 PM
Capt.Schenk
Jun 26, 2012 05:31 PM
twowheeled
Aug 23, 2011 10:30 AM
bean440
Apr 23, 2006 10:59 AM
PCola
Jul 11, 2003 02:09 PM
