Can't locate oddball Door Code "04"
Old Sep 29, 2004 | 11:02 AM
poboy66's Avatar
poboy66
Question Can't locate oddball Door Code "04"
My 1981 F100 302 AOD Short Wheel Base door code under axle says "04".
I can't seem to be able to find it anywhere on the net. The tag on the rear itself is missing. The rear is a 9" that's all I know. Any help in determining the ratio would be greatly appreciated. I'm trying to determine what size tire to go with and don't want to go to large with a gear like a 2.75.
Also the old 302 is being replaced with my recently completed HP 302 and I would like a little more low end grunt, knowing my rear ratio would help me have a better idea how the truck will perform. Any Idea what an "04" is?
Old Sep 29, 2004 | 11:44 AM
hdgapeach's Avatar
hdgapeach
http://www.medicine.wisc.edu/~mrm/bronco/ftvin.cgi
Go to that site and type in pertinent info and see what you get. If no axle info is given, check your build date on the plate and see if the truck was built close enough to '82 to maybe have an early '82 axle installed. If so check the '82 axle codes and see if there is a listing for "04". I know some of the earlier Mustangs were fitted with some of the next year's parts close to the model year change over. Just a guess whether the same would apply with the trucks.
Old Sep 29, 2004 | 12:11 PM
poboy66's Avatar
poboy66
Thumbs up
Ok, thanks
I will give it a shot
Old Sep 30, 2004 | 08:17 AM
poboy66's Avatar
poboy66
Arrow Update on 1981 F100 axle code "04"
I found out upon much searching that the "04" axle code for an 81 F100 is a 3.25:1 ratio, not great but better than the 2.75:1 that I feared I had.
fishhook05
2004 - 2008 F150
May 9, 2007 12:13 PM
Buck Rogers
Jul 25, 2005 11:39 PM
millwood1
Dec 16, 2003 06:29 PM
rowdy200
1997 - 2003 F150
Jun 18, 2003 09:55 PM
