Rough ride
Old 09-29-2004, 08:44 AM
snipa's Avatar
snipa
snipa is offline
Rough ride
My 53 f-100 has original springs. Would some delux shocks help to smooth the rough ride (very bouncy, and near whiplash when I ride over train tracks)
Or do I need new springs?
I want to avoid going custom
Thanks
Todd
Old 09-29-2004, 08:55 AM
GreatNorthWoods's Avatar
GreatNorthWoods
GreatNorthWoods is offline
Originally Posted by snipa
My 53 f-100 has original springs. Would some delux shocks help to smooth the rough ride (very bouncy, and near whiplask when I ride over trian trackS)
Thanks
Todd
Todd,
What you need is a suspension update. The Volare IFS rides very smooth. But, if you intend to keep the old suspension, the best you can do is remove some of the leaves in the springs (assuming you don't need maximum load capacity) both front and rear and put button sliders or teflon between the leaves. This will also lower the truck some. If your shocks are worn, new shocks may help some, but don't expect miracles. It's still a buggy spring suspension...
Vern
Old 09-29-2004, 09:20 AM
Third Coast's Avatar
Third Coast
Third Coast is offline
Along the same lines, what shocks would those on the board recommend as replacements. I intend to leave my 50 model stock but do need to install some new shocks.
Old 09-29-2004, 09:48 AM
Jag Red 54's Avatar
Jag Red 54
Jag Red 54 is offline
What do you mean by bouncy? Is the suspension very stiff or does the truck keep bouncing up and down for a while after you clear the tracks? If you are like mine on the rear, then they are just too stiff. My 54 doe not carry any load in the bed, so I have reduced the number of springs down to 5. I plan on making that 4 (ala Dewayne's recent adjustment) this fall.v If it continues bouncing, then it sounds like the shocks. Good luck, John
Old 09-29-2004, 09:52 AM
snipa's Avatar
snipa
snipa is offline
Thanks for the reply's guy's
The ride is very very stiff- so I'll try reducing the spring # like you've suggested.
Do you pound them out 1 at a time? Is there an article for this?
I'm so glad there is a site like this
Todd
Old 09-29-2004, 10:04 AM
Jag Red 54's Avatar
Jag Red 54
Do a search on springs and rough rides. There have been many threads on this topic. The whole shebang has to be removed except for the longest spring. After the center retaining nut is removed, the bolts that hold the springs in the shorter spring brackets are removed, then the large c-bolts that hold the springs to the axle can be removed. Use good jackstands, John
Old 09-29-2004, 10:52 AM
oldjeep's Avatar
oldjeep
oldjeep is offline
A 50 year old truck that was built to be used as a truck rides rough? Hard to believe
GreatNorthwoods - you obviously have no idea what a buggy spring is
Old 09-29-2004, 11:44 AM
don1077's Avatar
don1077
don1077 is offline
Snipa: I had the exact same thing. I did a total front end rebuild to get rid of any slop. Pulled leafs from the front, I am running with 4 now. I went with
a set of good quality gas shocks up front. I also installed the plastic spring
liners between each leaf after sand blasting and filiing burrs off all the ends and edges of each spring. The ride has improved a good bit, but the term "rides like a truck" came from these solid axel front ends.
Ps those liners came from Mid fifties. Also I was advised by the local spring guy to keep the 2 longest spring leafs. This will drop the front end about an inch. you can see the results in my gallery.
Don
Old 09-29-2004, 04:32 PM
barry's Avatar
barry
barry is offline
Everyone complains about the ride in these old trucks. You have to remember what you are driving, a truck! They were not designed like today's trucks, which are nothing but a car in disguise. They were meant to carry a load, haul lumber, etc... AKA.... work! Gas shocks are the best way to go, make sure all your bushings, etc.. are tight, steering box is tight and adjusted properly. Then it will ride like it was engineered to do, a 50+ year old truck. I think we've all been spoiled by the way newer vehicles ride and try to compare them to our antiques. It's like comparing Filet Minon to hamburger. I expect my 50 to ride like a brick, but that's half the fun of driving a old truck.
My 2 cents......
Barry
50 F-1
Old 09-29-2004, 08:18 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
1948 - 1960 Ford Trucks - Built Tough - Ride Rough. Enjoy the advantages of Big Arm Steering, 50 X 2 Open Window Airconditioning. Comes equiped with all the Rattles, Sqeaks and Groans you'll ever want.
Old 09-29-2004, 08:40 PM
JDMick's Avatar
JDMick
JDMick is offline
I've got the monoleafs on my truck but I couldn't tell you if they're any better than multileaf or multileaf with some leaves taken out since I replaced them before I ever drove the truck. Maybe somebody knows. One thing I do know is that not all new trucks ride like Cadillacs. The ride on my 2003 Dodge 3/4 ton 4X4 with a straight axle front end isn't much better at all than my 50 Ford. It needs at least 500 lbs. in the bed to smooth things out. The old trucks at least had some springs in the seat to help things out. Of course the trade off is the bouncing but that's part of the fun of driving these things!
Old 09-29-2004, 10:17 PM
himmelberg's Avatar
himmelberg
himmelberg is offline
I'm not sure what a "good" ride in a truck is supposed to be. There's a truckload of subjective on this subject. My late model ('01) truck drives just like a truck. I'm pretty sure we won't agree on what kind of ride our trucks should offer. We're all different, our trucks are different, as are our needs and on and on into the direst tedium.
The advise offered, on the other hand, is the best to be had anywhere. Bounce on there, whiplash and enjoy. best. himmelberg
Old 09-30-2004, 02:47 AM
James 3F1s's Avatar
James 3F1s
James 3F1s is offline
Put 4 or 6 100lb bags of sand in bed cheap ride adjustment add more or less.
Old 09-30-2004, 07:27 AM
55Bubba's Avatar
55Bubba
55Bubba is offline
My truck was doing the same thing and I put on some new Monroe Gas Truck shocks and tightened up everything in the steering system including new steering box and it rides absolutely wonderful.....for 50 year old truck ! Looking forward to removing some springs to get the ride a little smoother.
Good luck
Bubba
Old 10-01-2004, 07:36 AM
Midnite Cruiser's Avatar
Midnite Cruiser
Midnite Cruiser is offline
We love that extra headroom on our straight axle trucks. Keeps us from breaking our necks when crossing RR tracks at 10+mph
Quick Reply: Rough ride
