Hey all
I have a 2001 V10 4x4 with 35" tires 4.30 gears & an auto trans. i also have the superchips micro tuner.
my question is how are you all setting these up, right now i have only played with the 87 octaine setting using the the superchips settings. i'm not sure about
how to set up shift points or pressures, more information on different settings would be a good thing. are there any dyno curves or anything out there to show different set up changes? i'm not afraid to play with it but more info will help me make better choises
They can't give more information about the advanced settings. There are too many different uses, gear ratio configurations, PCM codes and models to cover in the book. The changes are there for you to play around with an find something you like, not everyone likes the same thing. Try incremental changes for a few days at a time.
