Lift
Old Sep 28, 2004 | 02:43 AM
Myckel's Avatar
Myckel
Lift
I just want to lift my x up about 1.5 to 2.5 inches does anyone have any idea how i can do this as cheap and easy as posseble to my 2002 V10 X 4x4
Myckel
Old Sep 28, 2004 | 03:06 AM
Monsta's Avatar
Monsta
Sit. Stay.
Upgrade your springs to Ford X-springs and a 4 inch block out back.
Old Sep 28, 2004 | 06:31 AM
Pungo's Avatar
Pungo
Monsta,
I was thinking the same thing for my X. I've searched the forum for V & X spring info but all I have found is how much lift they provide on the X. How do you identify them...is there a code stamped somewhere? I plan on visiting the local 4x4 shops and want to make sure I get the correct springs. I also assume when you get the springs it's just the front and Ford just varied the rear blocks on the superdutys to account for the front springs.
Old Sep 28, 2004 | 07:51 PM
Myckel's Avatar
Myckel
X-Springs
Does anyone know the part number for Ford X-spring, or were to buy.
Myckel
Old Sep 29, 2004 | 03:29 PM
Myckel's Avatar
Myckel
were can i get these springs and do you have a ford part number if i can get them from Ford
Thanks Myckel
Old Sep 29, 2004 | 03:35 PM
Toyman's Avatar
Toyman
If you call your local ford parts dept you need to tell them you want springs for an F250 with a snow plow prep package. These are the X code springs I don't have the number from Ford.
Good luck
Toyman
Old Oct 1, 2004 | 02:59 AM
Myckel's Avatar
Myckel
Thanks for your help I got it here are the part numbers
(2) 2C3Z-5310-AF Springs @ $154.32 ea
(4) F81Z-5705-ZA U-Bolts @ $15.88 ea
(8) N805480-S426 Nut @ $1.86 ea
Myckel
Old Oct 12, 2004 | 07:07 PM
TEX EX's Avatar
TEX EX
How much lift did that give you? Kind of curious as I would like to do something similiar to my 01 4X4 Ex PSD.
Thanks!
Old Oct 12, 2004 | 09:54 PM
Myckel's Avatar
Myckel
Arrow
The X-springs are on backorder at the factory I,m looking for the 4'blocks does anyone know whitch ones i need and where to get them.
Myckel
Leatherneck W5
Nov 22, 2016 11:51 AM
1972fordhighboy2
Sep 8, 2016 05:09 AM
bubbareitz
Feb 23, 2015 11:33 AM
sju96ford
20
Mar 29, 2012 07:57 PM
Trojan8975
Jul 5, 2011 03:17 PM
