Lift
Old 09-28-2004, 02:43 AM
Myckel's Avatar
Myckel
Myckel is offline
Lift
I just want to lift my x up about 1.5 to 2.5 inches does anyone have any idea how i can do this as cheap and easy as posseble to my 2002 V10 X 4x4
Myckel
Old 09-28-2004, 03:06 AM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
Upgrade your springs to Ford X-springs and a 4 inch block out back.
Old 09-28-2004, 06:31 AM
Pungo's Avatar
Pungo
Pungo is offline
Monsta,
I was thinking the same thing for my X. I've searched the forum for V & X spring info but all I have found is how much lift they provide on the X. How do you identify them...is there a code stamped somewhere? I plan on visiting the local 4x4 shops and want to make sure I get the correct springs. I also assume when you get the springs it's just the front and Ford just varied the rear blocks on the superdutys to account for the front springs.
Old 09-28-2004, 07:51 PM
Myckel's Avatar
Myckel
Myckel is offline
X-Springs
Does anyone know the part number for Ford X-spring, or were to buy.
Myckel
Old 09-29-2004, 03:29 PM
Myckel's Avatar
Myckel
Myckel is offline
were can i get these springs and do you have a ford part number if i can get them from Ford
Thanks Myckel
Old 09-29-2004, 03:35 PM
Toyman's Avatar
Toyman
Toyman is offline
If you call your local ford parts dept you need to tell them you want springs for an F250 with a snow plow prep package. These are the X code springs I don't have the number from Ford.
Good luck
Toyman
Old 10-01-2004, 02:59 AM
Myckel's Avatar
Myckel
Myckel is offline
Thanks for your help I got it here are the part numbers
(2) 2C3Z-5310-AF Springs @ $154.32 ea
(4) F81Z-5705-ZA U-Bolts @ $15.88 ea
(8) N805480-S426 Nut @ $1.86 ea
Myckel
Old 10-12-2004, 07:07 PM
TEX EX's Avatar
TEX EX
TEX EX is offline
How much lift did that give you? Kind of curious as I would like to do something similiar to my 01 4X4 Ex PSD.
Thanks!
Old 10-12-2004, 09:54 PM
Myckel's Avatar
Myckel
Myckel is offline
Arrow
The X-springs are on backorder at the factory I,m looking for the 4'blocks does anyone know whitch ones i need and where to get them.
Myckel
Leatherneck W5
11-22-2016 11:51 AM
1972fordhighboy2
09-08-2016 05:09 AM
bubbareitz
02-23-2015 11:33 AM
sju96ford
20
03-29-2012 07:57 PM
Trojan8975
07-05-2011 03:17 PM
Quick Reply: Lift
