shift knob
Old Sep 27, 2004 | 10:51 PM
ford89t's Avatar
ford89t
Question shift ****
I have been having a problem getting my old shift **** of to replace it it dose not screw off i have a 1989 F-350 man. 5 speed
Old Sep 27, 2004 | 11:23 PM
andym's Avatar
andym
Pull hard enough and it will come off. There's nothing holding it on, really.
Old Sep 28, 2004 | 06:32 AM
nastruk95's Avatar
nastruk95
I used a pair of channel locks and a lot of twisting and pulling.
Old Sep 28, 2004 | 06:40 AM
deekon's Avatar
deekon
Trailering
the heat from the texas sun makes mine come loose.
deekon
Old Sep 28, 2004 | 09:25 AM
low92flareside's Avatar
low92flareside
vice grips around the shaft below the ****, pry up with a screwdriver. that's unstuck quite a few for me!
Old Sep 28, 2004 | 09:53 AM
4x4fordtrkn's Avatar
4x4fordtrkn
I wouldn't twist it too much, cause the grooves run up and down not in a twist. You don't want to mess it up permantly.
Old Sep 28, 2004 | 10:25 AM
EPNCSU2006's Avatar
EPNCSU2006
heat the shifter and pull on the plastic ****, it should come off.
Old Sep 28, 2004 | 03:15 PM
BigBlue88's Avatar
BigBlue88
Lucky you. Mine comes off by itself. During the test drive, I tried to do a 4-3 downshift and my fist hit the dashboard. It was like one of those cartoons; I just stared at the **** in my hand for about a half a second before I grabbed the lever instead. Fortunately there was no traffic.
Old Sep 28, 2004 | 06:22 PM
ford89t's Avatar
ford89t
Talking
i think i will heat it since that is what most of you said to do thank you for your help. and big blue88 that is funny the **** for my transfer case always comes off which sucks but its the only problem
mj_355
Mar 21, 2014 09:12 AM
rat49f6
21
Aug 18, 2009 03:55 PM
hotwheel_2000
1983 - 2012 Ranger & B-Series
Mar 1, 2007 04:36 PM
brider
May 19, 2006 05:02 PM
lilman320
Appearance & Dress-Up
Feb 26, 2005 10:38 AM
