Sponsored by: Kumho
opening a bleeder plug
Old Sep 27, 2004 | 03:21 PM
h-m's Avatar
h-m
Hi all. I did almost the full brake system on my truck yesterday. The only thing i didn't replace was the Left front Caliper. I tried to bleed the system and couldn't get the bleeder to open on this one. How do you guys get a stuck bleeder open????? I stripped the hex's off the plug and got a vise grip on it and it still wouldn't get it to budge. I used a good penetrating oil and even put a little heat to it with the torch and it still didn't open. How do you get these stuck bleeders open???? I thought about welding a nut to it so i could get a socket on it. Do you think if i keep messin' with it by welding the nut on it, will the heat screw up the caliper??? this one was working ok, so i didn't replace it.
thanks for the help guys.
micheal
Old Sep 27, 2004 | 04:14 PM
fishmanndotcom's Avatar
fishmanndotcom
easy outs or left handed drill bits! use the biggest you can as the small ones tend to break....then you will have to get a new bleeder screw but that's like $1 or so
-cutts-
Old Sep 27, 2004 | 05:53 PM
aurgathor's Avatar
aurgathor
You can always try a screw extractor... you can help it by mildly heating up the caliper and cooling down the bleeder screw. If all else fail, there's always caliper replacement.
Old Sep 27, 2004 | 10:27 PM
03f150man's Avatar
03f150man
try PB Blaster as a penetrant.
Old Sep 27, 2004 | 11:01 PM
andym's Avatar
andym
This wasn't your question, but you should never replace calipers one at a time. Always in pairs.
Old Sep 28, 2004 | 06:29 AM
drydocked's Avatar
drydocked
Trailering
I've had good luck loosening them by smacking the bleeder screw on top with a hammer at the same time that I have a wrench on it pulling, using a good closed end wrench so it wouldn't slip. I'd always try that first and if that didn't work then some heat from a torch would do it. If neither one of those tricks works you might be looking at a new caliper.
Joe
Old Sep 29, 2004 | 07:06 PM
aurgathor's Avatar
aurgathor
Why?
Old Sep 30, 2004 | 12:06 AM
Hypoid's Avatar
Hypoid
The simple logic is that if one wear part is going, or gone; it's counterpart isn't very far behind. Of course, there's exceptions, variables, and probably some pretty good technical explanations.
For me it's cheap insurance, consistency, and peace of mind. The Mrs. expects to hop in anything we own, go any place she wants, AND make it home without worry or incident. Sounds reasonable to me. After all, I'm the resident gearhead, not her.
have fun, Mike
PS, I'm surprised no one recomended tightening a little to break that crusty thing loose.
Old Oct 13, 2004 | 08:30 PM
matt0963's Avatar
matt0963
i agree, dont waste anymore time on it, just get another caliper and be done with it, then you will have a COMPLETELY new brake system, the calipers are not that expensive anyway.
Old Oct 14, 2004 | 12:41 AM
andym's Avatar
andym
Because different calipers of different age, exposure to elements, amount of use, amount of internal wear, etc., not to mention potentially different manufacturers and different materials, will have different performance characteristics.
In other words, don't complain when your truck pulls to one side, or wears pads out unevenly.
Rotors and drums are the only parts you don't have to replace in pairs.
Old Oct 14, 2004 | 02:29 PM
h-m's Avatar
h-m
I think i will just replace this one also, so i don't have any issues with it any more.
thanks very, very much for all the replies.
micheal
BBslider001
33
Nov 4, 2014 06:14 AM
Vic_Young
2004 - 2008 F150
May 4, 2012 01:39 PM
Neil64
Apr 6, 2010 10:19 AM
bddo
17
May 22, 2006 04:08 PM
