96 Explorer Transmission Question
Old Sep 27, 2004 | 12:14 PM
ring85000's Avatar
ring85000
Question 96 Explorer Transmission Question
My 96 Explorer has 101,000 miles on it. I have changed the fluid and filter at 35, 65 and 99000 miles. After setting all night, then restarting the next morning, the tranmssion does not want to immediately go into gear. Almost as if it were low on fluid. After its warmed up and you get a few miles down the road, everything works fine all day long. What could be wrong?
Old Sep 27, 2004 | 10:38 PM
carfreak113's Avatar
carfreak113
Neutral Safety Switch???? Fishin on that one but my Bronc did the same thing and new switch solved it right away...
Old Oct 11, 2004 | 07:17 AM
ring85000's Avatar
ring85000
96 Explorer Transmission Fix
Just a quick report back to the group, I have fixed the problem with this transmission.
I changed the filter and flushed the entire system with T-tech at Mobil One.
The old filter was missing the O rings on the top of the filter where it fits up into the bottom of the transmission. The absence of the O rings caused more air than fluid to pass on into the transmission from the pan. This caused the delayed engagement when fluid was cold in the mornings.
Transmission working great now with 103,000 miles on it.
I hope my experience can benefit someone out there.
88dually
Aug 9, 2013 03:50 AM
cokewithvanilla
Oil & Lubrication
Jan 6, 2013 07:24 PM
1966racer
Dec 22, 2009 04:58 PM
jeansain
Oct 21, 2009 08:55 PM
capt scott
Jan 28, 2002 05:41 PM
