Converting from R12 to 134
Compressor seems to be working and have checked the system and it is totally empty of the old R12. (not even a hiss when depressing the service valve)
Do I need to have a vacuum pulled before the change over or is that just to check for leaks?
Since it's been dead for SO long do I need to replace the drier/accumulater?
Anyone tried the "leak sealer/Oring conditioner" kits for 134 with any luck just in case there is a leak ... or would this be a good thing to do BEFORE re-charging the system after the change over?
Thanks!
You NEED to suck down the system even though it is empty. This is because moisture can get in the system, which will turn to ice if the system has not been sucked down really well. So yes, suck it down man...
As for the drier/accumilator:
It's always something that is going to be easy to replace if the system is not working up to par. I say charge it up and see if it's working fine. If so, don't change it.
The O-Ring seal/conditioner did not work for me, but I had a leak at the body of my compressor (which it CLAIMS to seal.)
Anyway, good luck.
Mark
Thanks for the info. See now the need to go ahead and pull the vacuum. Will let the drier ride unless I need to change it out.
Don't have the gear to suck it down but hopefully can get a shop to do it without charging an arm and a leg.
Changed over my wife's '92 Sunbird last summer and shop wanted $400 for the changeover!! (this did NOT include the kit which is like $30 and includes the coolant) Friend of mine did have the gear and he did it for $50 (pulled a vacuum and we changed the drier). So with kit and EVERYTHING was under $100. He has since moved away ...
I realize the R134 is not as cold ... but we only notice it when she's sitting idle. Once the car is moving it'll freeze you out and the stuff is SO much less $ than the R12.
Mark
Thanks for the offer but I'm hoping this is my LAST conversion! I know just about enough about auto AC to blow my dentures into my neighbor's pool!!!
Jim
