Automatic transmission shifter linkage adjustment
Old Sep 26, 2004 | 08:29 PM
joepechin's Avatar
joepechin
My shift linkage on my 99 Ranger automatic is out of adjustment. Everything works normally but the detents on the column shifter are not matching the appropriate gear. Is there a means of adjustment? Thanks! Joe
Old Sep 26, 2004 | 08:34 PM
Help I M Stuck's Avatar
Help I M Stuck
take the bottom panel off the dash where your knees are..there is a little thin wire that goes thru a black thumb wheel that loops around the steering column..try spinning the wheel and adjusting it..it's possible the plastic feed broke and is causing slack..good luck.
abyars111
Feb 12, 2016 08:30 AM
Gigemags05
1947 and Older Ford Trucks
Dec 3, 2014 04:24 PM
marvinlong
18
Jan 30, 2014 03:04 PM
fishpimp
Jan 1, 2010 06:16 PM
workingdog
Jun 15, 2006 04:28 PM
