General Automotive Discussion
Winter bed weight recommendations?
Old Sep 27, 2004 | 12:49 PM
VinMan's Avatar
VinMan
Originally Posted by alfama351
if you are shoveling snow, shovel it into the back of the truck, unless you need the cargo area. racsan has great advise by filling an extra tire with sand, going to try that myself. BTW 4wd works really well too
I used to do the snow in the bed thing until one time when i needed to put something in the bed, and I had to use an axe to chop out the foot and a half of snow that turned into solid ice.
Old Sep 28, 2004 | 11:16 AM
jessfactor's Avatar
jessfactor
i throw some 2x's together in the bed to keep the sand bags right over the rear axle. you only need about 200 lbs back there. if your worried about the sand bags hitting you in an accident then use 2x10's to make the jig (piece in front of the wheel well, piece behind, and two pieces connecting them) and then secure a sheet of plywood over the 2x10's. you really onle need about half a sheet, if that. the front of the bed isn't the best place for a 2 wheel drive truck because you want the weight over the axle. you would have to put 3 times the amount in the front of the bed to make a difference for the rear wheels. just make the 2x's nice and tight so that the jig and the sandbags hsve no room to shift.
Old Sep 28, 2004 | 11:36 AM
Freightrain's Avatar
Freightrain
I've never put any weight in any truck I have owned. Granted I don't go places that I shouldn't...but I always make it to where I'm going.
4WD=getting even more stuck before you have to have someone pull you out
Old Sep 28, 2004 | 06:57 PM
FM FordFan's Avatar
FM FordFan
When I had my Ranger, I used about 350 pounds of tube sand. Last winter there was not enough snow to put weight in the back of the F250.
Old Sep 29, 2004 | 01:29 AM
big hoss 29's Avatar
big hoss 29
I usually put a couple of bails of alfalfa in the bed and throw 'er into 4 high.
Old Sep 29, 2004 | 02:37 AM
coplin's Avatar
coplin
Throw your mother-in-law in the back and ratchet strap her down. When she freezes it'll add even a little more weight.
cowboybootlegger
18
Sep 3, 2015 08:39 PM
smlford
Aug 7, 2015 04:32 PM
jgdrcr
Mar 2, 2015 10:42 PM
ghunt
Sep 13, 2008 06:18 AM
jobeck1
15
Dec 5, 2002 03:01 PM
