1978 - 1996 Big Bronco
sway bar?
Old Sep 26, 2004 | 10:06 AM
razell's Avatar
razell
sway bar?
i have a 79 bronco just purchased. it had a broken bolt that connected the "sway bar" to the frame. i replaced the bolt, drove it to work and back home ( about 10 miles ), as soon as i got home i checked it and sure 'nuff it was broken again. is this an aftermarket bar or what? it also has one in the rear which also attaches to the axle housing.
Old Sep 26, 2004 | 11:44 AM
greystreak92's Avatar
greystreak92
Could be the bushings are bad and its binding too much. That could cause the problem. I assume you replaced the bolt with grade 8 hardware.
Old Sep 26, 2004 | 07:47 PM
razell's Avatar
razell
yes i did go with grade 8. when i went the parts store & told them what i needed i got the bushings (these where the same as those i took off) and a bolt about 2 1/2 in. long. the one i needed was 8 in. long. an obvious communication problem. the next time i asked i was told that was a "non-stock" item & they couldn't order it. i need to switch parts stores.
Old Sep 26, 2004 | 09:01 PM
Jdenninger's Avatar
Jdenninger
razell, are you talking about the "bolt" that goes from the frame to the sway bar? if so the only place i have seen that carries this is LMC truck. both of mine are brokena and have been for months. they are about $40 each.
Old Sep 27, 2004 | 06:12 AM
razell's Avatar
razell
yep, that's the one. about a 3/8 bolt with a shoulder 2/3s of the way down. so this is not an aftermarket bar? guess i'll have to search around & find out who does have it. it'll bug me 'till i get it fixed. thanx 4 the info.
Old Sep 27, 2004 | 10:33 AM
Kemicalburns's Avatar
Kemicalburns
take the sway bars off. there not really needed and will improve flex while offroading.
eastvanmikee's Avatar
eastvanmikee
unless your hauling a trailer or boat..lose the sway bar, much better suspension travel for off road.just my $0.02
Old Sep 27, 2004 | 11:51 PM
Jdenninger's Avatar
Jdenninger
only take it off if your bushings are good. if not your sway will be amplified.
Old Sep 28, 2004 | 01:52 AM
mustangman65_79's Avatar
mustangman65_79
mines a city truck right now, and the way I drive, they r staying on-lol
Old Sep 28, 2004 | 09:55 PM
4whlnut's Avatar
4whlnut
I have a Rancho 4" suspension lift. I haven't ran a sway bar for two years. Take it off!
oldford65
May 26, 2012 11:38 AM
Sycostang67
Sep 9, 2010 08:05 PM
Dave S
Feb 9, 2006 09:12 AM
cairatti
Feb 13, 2004 08:52 AM
heep70
Jul 15, 2003 12:37 PM
