1978 - 1996 Big Bronco
Electrical Nightmare
Old Sep 25, 2004 | 09:38 AM
wantadrive's Avatar
wantadrive
1989 5.0 Eddie Bauer have an electrical DRAIN, charge the battery it holds
ad the negative it holds ad the positive it starts to drain in about 8hrs the battery is dead.........is there a common bad cable? Started pulling fuses have not stopped the flow HELP!!!!!!! starting to lean twoward ignation (key switch)
any ideas will help
Old Sep 26, 2004 | 07:44 AM
dcotton's Avatar
dcotton
Pull the fuse (both) for your stereo (the stereo is a constant draw), take off either your positive or negative battery cable, put a amp meter or test light between the two and one at a time pull fuses. When the amp draw goes away or the light does not light any more then you have found the problem. You also need to trace any wiring that comes directly off of the battery, you could have a relay or solenoid sticking also.
You also could just have a bad battery.
My 2 cents worth. D
Old Sep 26, 2004 | 08:28 AM
BroncoWY's Avatar
BroncoWY
Dirty battery terminals will act like that too. The car will run fine when the alternator is charging but when you try to send 40 amps to the starter, the dirty terminals will have too much resistance; but the solenoid will click so it sounds like the battery is dead. Clean your battery terminals with a wire brush and check the condition of your cables.
A slipping alterator belt is a possibility too.
Old Sep 26, 2004 | 08:36 AM
1081's Avatar
1081
you might take some time and read this thread and see if it helps.
http://fordtrucks.com/forums/showthread.php?t=267713
Shmit90051
Jan 23, 2013 10:20 PM
fordtough81
Sep 5, 2012 10:25 PM
MuddyWaters
Aug 2, 2010 11:34 AM
joefromil
1997 - 2003 F150
15
Mar 29, 2008 09:37 PM
pyr0maniac
Jun 1, 2002 06:19 PM
