Bronco II Ford Bronco II
Bronco II
Old Jul 22, 2002 | 06:25 PM
Avanti's Avatar
Avanti
Bronco II
Old Jul 23, 2002 | 04:27 PM
countryboy29's Avatar
countryboy29
Bronco II
Thinking about buying one to go along side my big bronco. How easy is to jack up these vechiles, how are they at off roading. Also since they're not as wide do they tip easier? Thank you
Old Jul 25, 2002 | 09:12 AM
mickelsons's Avatar
mickelsons
Bronco II
I loved the one I had, with out a lift it off roaded awsome and the wheel travel is outstanding. The lift on them is not much differant than any twin traction IFS system Ford has used. or of course the body lift. I guess that they would be a little more tipsy since they are narrower, but it all depends on your driving.
Scott
Old Jul 26, 2002 | 07:34 AM
BKSasquatch's Avatar
BKSasquatch
Bronco II
Skyjacker or James Duff Inc (or enterprises) both make lifts for BII's
Mine is not really lifted ('90 Eddie Bauer) but I have added helper springs in the back to keep it from sagging. I also have wheels,
American Racing on it that have more offset with LT235 tires
that have added about 4 inches to the overall width (2" per side) The lifts I have been looking at are around $375-$500 to get 3" or 4"
suspension lift. I have also heard of a cheap way to have disconnectable sway bars but I haven't had the time to do it yet.
As far as off road goes, I am a Coloradoan temporarily living in Utah and we have had a blast in Moab and some of the canyons around here.
I tried going up a "hill" that is steeper than @$#% a month or so ago
when I lost traction (it felt like I was driving straight up when that happened) I started backing down. By mistake put my drivers side rear wheel into a hole about 4-5 feet deep and at a huge angle sideways. All of a sudden I felt the front passenger wheel pull up and when my buddy riding shotgun opened the door and leaned out to see how far off the ground it was he said about 4 feet.
We got down ok after careful wheel placement then I found out that that same hill defeated my neighbors Jeep Wrangler (2002, 3" lift, 32x12.0 tires) so I didn't feel bad. This got long... the main thing about off-roading is get tires for the area you are at. Out here that is Huge lugs and then aired down to 12#-20# psi for a bigger footprint.
Brian
90 BII EB
brian31@xmission.com
Old Jul 26, 2002 | 09:53 PM
countryboy29
Bronco II
Thank You for the input gentlemen. Take care now and good muddin.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
