Sponsored by: Real Truck
Please Help F250 blown engine
Old Sep 24, 2004 | 06:01 PM
chrisj1970's Avatar
chrisj1970
I do no now if this is the appropriate forum but I bought a brand new f250 with the v-10 about a month ago. It never did quite idle right and every now and then it would not start. Well today my wife tries to start it and it doesn't start. It has been in the shop 3 times to diagnose this problem. It never happened to the dealer. Well after it didn'd start today she called the dealer and a service tech came out and said it was a bad starter. He got it started and was about a block away from the dealership and white smoke comes out of the tail pipe. To make a long story short valve number 7 has antifreeze in it. The coolant was leaking into the block.The motor oil was soopy. Motor is toast. Ford says they will replace engine. I want a new truck. It has only 500 miles on it and I bought a new truck not a used one. What do you guys think?
Old Sep 24, 2004 | 07:09 PM
Heaterman's Avatar
Heaterman
You will be lucky to get a new engine. Most likely you will get a factory rebuilt
Old Sep 24, 2004 | 07:28 PM
Yeti's Avatar
Yeti
Get your lawyer involved..can't hurt
Old Sep 26, 2004 | 07:32 PM
HD1340's Avatar
HD1340
I am a automotive tech,and worked 2 yrs in a ford dealer. I replaced a few engines
under warranty,and if the vehicle has less than 16,000 miles on it they should give
you a brand new motor,not a rebuilt.
Old Sep 26, 2004 | 08:54 PM
Heaterman's Avatar
Heaterman
THey kept putting factory rebuilts in my 97 E250 The tranny died with 8 k on it I finnally got rid of the truck after the third tranny went in with 25k on it To bad too I liked that van it was set up the way I wanted it but it was just a lemon
jdelrizzle
6.7L Power Stroke Diesel
20
Apr 1, 2016 09:03 PM
ibew
New Member Introductions
Jan 25, 2016 11:56 AM
FritzFord
Aug 18, 2015 08:11 PM
topnotch286
6.4L Power Stroke Diesel
May 23, 2010 10:47 PM
jdschall
1983 - 2012 Ranger & B-Series
May 12, 2004 08:59 PM
