1978 - 1996 Big Bronco
How to remove an ingition module?
Old Sep 24, 2004 | 05:13 PM
spike677's Avatar
spike677
I have an 89 Bronco with a 302 and was told that the ingition module was probably bad, so my question is how do you get it off? There are two screws that hold it on the distributor body but can only get the wrench on one of them. I am not a motor head at all and didn't want to find out by trial and error and then have to worry about the timing afterwards, Thanks.
Old Sep 24, 2004 | 05:50 PM
RLKBOB's Avatar
RLKBOB
You probably got the front one. To get at the back one I always loosen the dist hold down and turn the dist counter clockwise as far as I can then I can get to it. Mark where the dist is before moving it so you can put it back when you're done but you should still set the timing with a light after you're done.
Old Sep 24, 2004 | 06:07 PM
ChargerFan's Avatar
ChargerFan
If you need to remove the module, there is a "special" tool just for this. Parts stores sell them. 5-6 bucks I think. "Ignition Module Removal Tool". But I wonder if an Allen wrench in the appropriate size will work? Or is it a Torx? Anyway, they come off without much trouble and you don't have to mess with the distributor. Put di-electric grease on the new one.
Old Sep 24, 2004 | 11:24 PM
BigBody's Avatar
BigBody
I just had this done on my 1990 Bronco. I had to move air hoses and twist distributor. That tool ChargerFan mentioned, you can pick them at O'rileys or wherever for 4 or 5 bucks. Just make sure you clean off the heat transfer paste and apply your new coat well.
Kyle
Old Sep 25, 2004 | 01:34 AM
Torque1st's Avatar
Torque1st
Posting Legend
Remove ALL the heat transfer paste and clean the surfaces well. Apply new WHITE thermal transfer paste to the module and reinstall.
Old Sep 25, 2004 | 07:11 AM
spike677's Avatar
spike677
How to romove ignition module
The distributor body sits on a short post, is that what you fellas are talking about turning? There is a clamp on the bottom of the post that I loosened but it won't turn.
Old Sep 25, 2004 | 11:05 AM
greystreak92's Avatar
greystreak92
If your timing hasn't been messed with in a long time, the dist. may stick and require a little effort to get it to twist freely even after loosening the clamp. Just make absolutely certain that you mark the original position before you move it otherwise you will have to go back and reset the timing with a light.
Old Sep 25, 2004 | 03:44 PM
RLKBOB's Avatar
RLKBOB
Actually that "post" is part of the dist body/casing and yes you need to turn the whole dist body. As stated earlier you may need to put some muscle into it(make sure the hold down bolt is loose enough). even if you mark the initial position you should still reset the timing when you're done.
pumphrey27
Mar 14, 2013 02:07 PM
Bwag608
Apr 23, 2012 11:58 AM
ford501979
1983 - 2012 Ranger & B-Series
Jul 14, 2011 08:43 AM
kennyr
Jul 9, 2011 11:25 PM
SpankF100
Mar 22, 2006 12:11 PM
