1978 - 1996 Big Bronco
Carbed engines have computers?
Old Sep 24, 2004 | 04:03 PM
MatthewC's Avatar
MatthewC
This may sound stupid, but do carburated engines (84 351W HO) have computers, to get codes from?
If not, let the flaming begin.
-Matt
Old Sep 24, 2004 | 08:38 PM
Cloim's Avatar
Cloim
Some carbed engines had computers. Not sure which ones. Not sure what they did or if you could get codes from them.
Old Sep 25, 2004 | 10:19 AM
gman88's Avatar
gman88
Yes, carbed engines did have computers in the early years OBD1. They had a feedback circuit that would make slight alterations to fuel mixture. It also controlled the other necessary functions like timing. Not sure what years had it, but my my 1984 Ranger has this setup. Yes you can get codes from this system.
Old Sep 25, 2004 | 10:25 AM
F150'89's Avatar
F150'89
I know its not a FORD, but my '82 Buick Regal with a 3.8 V6 2bbl has a computer. It is diff from a Ford but I can read the codes without a code reader.
Old Sep 29, 2004 | 11:26 AM
Cheggie's Avatar
Cheggie
There's a Haynes manual that covers this - the setup is called MCU I think, and the book describes diagnostic procedures. It's worth having the manual if you've got one of these. I think they only lasted a couple of years
Old Sep 29, 2004 | 11:48 AM
Redbob's Avatar
Redbob
The earliest computer systems were EEC-III, and you got codes by turning the key on, grounding a plug (gotta think where it is) and then counting the number of times the check engine light flashes.
Crud; I can't find the info. Yeah, get hold of a manual, preferably Ford but Haynes are OK.
Old Sep 29, 2004 | 03:15 PM
hdgapeach's Avatar
hdgapeach
I think since '81 pretty much all vehicles had some sort of brain box in it. The first ones didn't regulate much, just monitored things so you could pull flashing light codes to narrow down troubleshooting a problem. I remember a cab swap on a '79 GMC to an '81 cab ('79 rusted out) and I bypassed the silver box on the '81.
Old Sep 29, 2004 | 10:24 PM
skelator's Avatar
skelator
your 84 has what is known as eec-iv, it is pretty much a computer assisted carb system. your computer is under the dash just to the left of the radio. if you take your truck the can test the computer, but they want about 80$ to do this. if you go to vato zone they will sell you alone with a new one for about 100$. now if your engine is running well enough to drive to the ford house, there is nothing wrong with your computer.
Old Nov 22, 2004 | 03:04 PM
88blkranger's Avatar
88blkranger
ok cool my 88 ranger has the mcu system in it and when I try to pull codes the scanner says that the vehicle does not respond. I'm having a rich mix and bad erratic idle (hops around 50-100rpm) any ideas?? my engine is 2.0L asian built 2bbl new complete tune up. even rebuilt carb still running the same.
