pesky distributor
Old Sep 23, 2004 | 11:16 PM
albracht2000's Avatar
albracht2000
pesky distributor
how in the world do you get a stuck distributor to unstuck. i'm ready to body slam it. any tricks or info would be appreciated. 78 400
Old Sep 24, 2004 | 12:42 AM
hdgapeach's Avatar
hdgapeach
Mucho PB Blaster/WD-40 over a couple of days with many attempts to twist it loose during the same time period. I've also used one of those newer strap wrenches to break one loose. Once you do get it thawed out, pull it out of the hole and coat the thing with a heavy grease or anti-seize so it don't happen again.
Old Sep 26, 2004 | 01:22 AM
paragod's Avatar
paragod
Don't try to pry it out. Those cases are breakable.
Old Sep 26, 2004 | 09:43 AM
albracht2000
what do you suggest, if wd40 doesn't work and dont pry it.
Old Sep 26, 2004 | 12:03 PM
hdgapeach's Avatar
hdgapeach
Go to the Garage and Workshop forum and click on the first thread "Read First". Scroll down to number five "The Candle Trick". Worth a shot if all else has failed. Works good for froze and broke bolts. Don't see why it wouldn't work for this too. Might toast the gasket or o-ring, but hey, they're cheap.
Old Sep 26, 2004 | 02:13 PM
paragod's Avatar
paragod
get some pb blaster. it works twice as well as wd-40 in my opinion. DId you try the strap wrench?
Old Sep 26, 2004 | 03:23 PM
Lifted78's Avatar
Lifted78
Get a can of Coke and pour it over the base. The acid in the Coke will loosen it. Put enough on so it can sit for a few hours and work its magic.
John
Old Sep 26, 2004 | 03:43 PM
paragod's Avatar
paragod
I have honestly never heard of pouring coke on anything but battery terminals or windshields. I will have to try that. Does it work on busting rust, or just on frozen parts?
Old Sep 26, 2004 | 03:50 PM
1081's Avatar
1081
I don't know, but body slamming the distributor might hurt a little!
Old Sep 26, 2004 | 07:14 PM
paragod's Avatar
paragod
Yeah, just a little shoulder check might make him fell a little better though
Kenny
Oct 26, 2002 10:08 AM
paveslave
May 26, 2002 05:03 PM
spshultz
Mar 13, 2002 09:51 PM
adelyser
1978 - 1996 Big Bronco
Jan 18, 2002 10:47 AM
lvstang
Dec 16, 2001 04:53 PM
