Slow Return To Idle
Old Sep 23, 2004 | 11:48 AM
aerocolorado's Avatar
aerocolorado
Slow Return To Idle
Greetings from your newest Ranger owner. While I am intimately familiar with the 4.0L engine, this Ranger is a 98' 3.0L with 83,000 miles, manual transmission. I have search this forum and the 3.0 for this problem without success. After warmup, the engine is slow to return to idle, staying around 2500 rpm for around 10-15 seconds before dropping to 1000. Im familiar with the antics of the IAC valve but this does not seem to behave like that. I suspect the EGR system but am not certain. Any hints?
Old Sep 23, 2004 | 12:41 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
I'd first inspect vacuum lines for damage, etc, then proceed to pull any codes.
Old Sep 23, 2004 | 01:18 PM
Mike W's Avatar
Mike W
Every day I pull off the freeway at 70. I then stop at the end of the off ramp. While waiting to make a left turn, I notice my tach is around 2000 rpm. I only see this happen during this stop, never just driving around town in my 01, 4.0.
Old Sep 23, 2004 | 01:35 PM
Rockledge's Avatar
Rockledge
Check to see if your Ranger is covered by this TSB:
Article No. 98-26-8
• IDLE—HIGH IDLE SPEED (1300-2000 RPM) DURING
CLOSED THROTTLE DECELERATION WITH THE
TRANSMISSION IN NEUTRAL OR WITH THE
CLUTCH DEPRESSED
• MALFUNCTION INDICATOR LAMP (MIL)—MIL
ILLUMINATED WITH DIAGNOSTIC TROUBLE CODE
(DTC) P0320 STORED IN MEMORY
• LAMP—MALFUNCTION INDICATOR LAMP (MIL)
FORD: 1998-1999 RANGER
CALIBRATION
8-49A-R06, 8-49B-R10, 8-49S-R10, 8-49T-R06,
9B1M-AA-A, 9B1M-AB-A, 9B1M-AC-A, 9B1M-BA-B,
9B1M-BB-B
WARNING
THIS MODIFICATION IS AUTHORIZED ONLY FOR
THE LISTED ENGINE(S). PERFORMING THIS
MODIFICATION ON OTHER ENGINE
CALIBRATIONS IS UNAUTHORIZED AND COULD
CREATE LIABILITY UNDER APPLICABLE
FEDERAL OR LOCAL LAWS.
ISSUE
The Malfunction Indicator Lamp (MIL) may
illuminate and Diagnostic Trouble Code (DTC)
P0320 may be stored in memory on some vehicles.
There may also be a high idle rpm (1300-2000) on
closed throttle deceleration in Neutral or clutch
depressed. This may be caused by the Powertrain
Control Module (PCM) calibration.
ACTION
Reprogram the PCM to latest calibration level. This
more robust calibration reduces deceleration air flow
and reduces the possibility of high rpm with high
limit hardware. In addition, the calibration error is
fixed to reduce the possibility of unique driver action
causing a false P0320 MIL code.
Obtain an Authorized Modifications Decal (FPS
8262 - obtainable through DOES II, 25/pkg) and list
the date, dealer number, and summary of
modifications performed. Select a prominent place
adjacent to the Vehicle Emission Control Information
Decal suitable for installing the Authorized
Modifications Decal. Clean the area, install the
decal, and cover it with a clear plastic decal shield.
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: Eligible Under The
Provisions Of Bumper To Bumper Warranty Coverage
And Emissions Warranty Coverage
Old Sep 23, 2004 | 03:22 PM
Mike W's Avatar
Mike W
For some reason I feel that Bill Gates is controlling our trucks. Yeah, we know there is a bug in the software; we will do a patch later.
Old Sep 23, 2004 | 05:32 PM
aerocolorado
Rockledge, thanks for the TSB info. Will do some checking on this.
Old Sep 23, 2004 | 05:47 PM
maticuno's Avatar
maticuno
If you aren't getting a check engine light, I would suspect a faulty connection in the Throttle Position Sensor wiring harness. There is a TSB about this fix too, but I don't have it available. I had the same problems you are experiencing and I seem to have at least temporarily fixed it by cleaning and fidgeting with the wire harness.
Old Sep 23, 2004 | 09:34 PM
Hank85713's Avatar
Hank85713
maticuno if you can find the TSB can ya scan and send? I have a bad wire in my wire bundle but dont know where. Have changed the TBS, IAC and no difference. I disconnected my IAC, have no problems but would like to know what the wire problem is.
Hank
94, 4.0
Old Sep 23, 2004 | 10:01 PM
Ken00's Avatar
Ken00
If someone has the number I should be able to post it.
Old Sep 24, 2004 | 09:46 PM
maticuno's Avatar
maticuno
I found the thread with the TSB. Here ya go!
https://www.ford-trucks.com/forums/s...d.php?t=236750
Old Sep 24, 2004 | 10:27 PM
Rockledge's Avatar
Rockledge
That TSB is applicable to Rangers with 2.5L engine...
Melansk
Dec 6, 2025 07:45 PM
sk8nmike
Computer Chips & Tuners
May 20, 2017 01:21 PM
gunrok
Nov 21, 2016 12:40 PM
tacomacream
Jul 16, 2016 05:56 PM
68Mercury250Ranger
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 21, 2004 04:51 PM
