Spark Plug Experience
Old Sep 23, 2004 | 11:43 AM
FAB150's Avatar
FAB150
Has anyone had a good experience with Bosch plugs in this model truck?
Old Sep 23, 2004 | 06:45 PM
triton_2002's Avatar
triton_2002
From what I've heard the stock replacements are the best on these engines.
Old Sep 24, 2004 | 12:59 PM
JH6's Avatar
JH6
bosch is the worst plug you can put in a mod motor.
Stick with stock motorcraft platniums or coppers.
Old Sep 29, 2004 | 01:42 PM
MitchPeters's Avatar
MitchPeters
After going through 2 sets of Bosch plugs and chasing misses after only a few thousand miles I went back to Motorcraft plugs. No more missing.
Old Jan 16, 2005 | 01:31 PM
mattd17's Avatar
mattd17
i have a 99 f250 sd with the 5.4. when i purchased the truck, it had 76000 miles on it, and it started missing just after i bought it (go figure). well, i ended up changing the # 4 cop and all the plugs with bosch platinum. i have always liked the bosch plugs, but after that the idle just didnt seem quite right, and i read a lot about the mod engines.... so i went out and just bought a set of motorcraft platinum and i am going to change them out today.... i hope i have the same results that you had.
Old Jan 22, 2005 | 06:24 PM
LilBlackCoupe's Avatar
LilBlackCoupe
Motorcrafts or Autolites
Old Jan 22, 2005 | 11:56 PM
LxMan1's Avatar
LxMan1
After having to replace the 5.0 in my dad's 89 F150 because the platinum center fell out of a Bosch Platinum plug and wedged in-between the piston and cylinder wall leaving a deep scar down the cylinder wall causing heavy blow-by, I'll never use them again.
As stated above, Either Motorcraft or Autolite double platinums are the only way to go!!
Old Jan 23, 2005 | 12:13 PM
FAB150's Avatar
FAB150
I have decided to go NO spark plugs. Loving the diesel!
Old Jan 24, 2005 | 10:20 PM
LxMan1's Avatar
LxMan1
That will work too
Fyrfyghtr
Aug 14, 2016 08:44 AM
pholmes350
Aug 7, 2016 12:25 PM
GJWallace
30
Apr 15, 2016 07:38 PM
tygerof2
Feb 15, 2015 06:00 PM
Serenity06
19
Jan 9, 2014 10:12 AM
