Hay guys not so sure if this belongs here. what 12v dash wire should i tap into to wire my autometer gauges? this makes them dim correct? is the *** that turns on the light the best place to tap to allow the gauges to dim? thx
That's where I tapped into mine at. It was the easiest. Pulled the light switch out, found the right wire, done.
Hay there are 4 wires on the slide switch dimmer. can you tell me the color of the one you tap into? Also is the stock temp gauge a probe in the block? or is there a radiator sensor? I found a black sensor i believe to be stock temp. if you are looking at the engine from the front it is on the right side in 1st cylinder? Any ideas guys?
