automatic shift ind. light bulb, inop.
Old Sep 26, 2004 | 06:45 PM
  #31
Justntimeracing's Avatar
Justntimeracing
Question auto. shift ind.light...
golfer, really like the color on your truck! always wanted one light green. gonna eventually paint mine the same color. question.....is your ign. on the dash or column? is the truck the orig. color?
Old Sep 26, 2004 | 08:53 PM
  #32
GolferSA's Avatar
GolferSA
Justntime...
No, it's a '67... the ignition is in the dash (see column pics above) on the left.
The color is Lunar Green (and Wimbledon White), original colors.
Old Sep 26, 2004 | 08:58 PM
  #33
GolferSA's Avatar
GolferSA
Originally Posted by BB
That's a '73+ column with the flasher there. Their PRND21 does light up and has two bulbs to do it, each on their own separate circuit...
Hey BB...
I never said thanks for solving the mystery... thanks!!
One of those 2 bulbs may have to go...
I'd hate to drive too far at night with them blaring at me!
Thanks again.. why I come to FTE,
Old Sep 27, 2004 | 07:48 PM
  #34
Justntimeracing
Lightbulb auto. column shift ind. light
Golfer, tx.i know your truck is a 67' was asking if ign. switch was on column or dash because the 73+ columns with the four-way emergency switch on the column, also, had the ign. switch on the column. if there is no sign of that someone did alot of modification. who ever you bought it from did nice work! anyways,....... figured out my auto. shift ind. light problem. i am going to install a steering column mounted, tach. with night illumination! anyone got a nice sun or autometer tach. for sale?
Old Sep 27, 2004 | 07:53 PM
  #35
GolferSA's Avatar
GolferSA
Not possible that someone put in a column with the ignition in, and removed all that... my guess is that someone took the lights out of the '73 column and stuffed them in my '67.
BB... mystery back on!
Old Sep 27, 2004 | 08:15 PM
  #36
Justntimeracing
Lightbulb auto. shift ind. light...
golfer, and put a 73+ steering column 4-way flasher switch in the column, and shift ind. night illum. light in your orig. 67 column? i doubt it very much. you have the newer column 73+ and they kept the on dash ign. all you do is switch the center column piece.
Old Sep 27, 2004 | 10:26 PM
  #37
BB's Avatar
BB
I don't know...
73+ pickups still had the key in the dash, I'm not sure what year it went to the column, '80? too new for me.
Old Sep 27, 2004 | 11:33 PM
  #38
GolferSA's Avatar
GolferSA
And there you have it... mystery re-solved. '73 column, key in the dash and 2 100w light bulbs lighting up the shift indicator... and half of San Antonio.
Old Sep 28, 2004 | 07:46 AM
  #39
7283-F250's Avatar
7283-F250
I thought I remembered my uncl's '79 having the ign. on the dash....
The 1980's model went through a lot of changes both interior and exterior. It was at that point the ign was put into the column, and the PNRD21 was put into the instrument cluster and lit up.
glenn 79
Aug 30, 2020 12:20 PM
Tom Norton
Feb 6, 2011 09:18 PM
shameless
Sep 18, 2010 11:16 AM
4AVIEW
Jun 25, 2003 09:22 PM
