Bronco II Ford Bronco II
Electric door lock
Old 09-30-2002, 02:56 PM
Hawk521's Avatar
Hawk521
Hawk521 is offline
Electric door lock
My electric door lock works on the passenger door and the hatchback only. The driver door doesn't unlock, nor lock via the lock switch on the side of the driver's door next to the power windows.
Is this normal? Or is there a wire loose inside my driver's door?
Also - did this BII XLT (1990) come with a remote door lock? Or is it key only?
Old 09-30-2002, 03:44 PM
motorbreath's Avatar
motorbreath
motorbreath is offline
Electric door lock
well, mine is exactly the same way, so it must be normal for us! im guessing the drivers one would wear out faster since its used more?
there are motors up on ebay sometimes.
86 b2 xlt 2.9 v6
Old 09-30-2002, 09:08 PM
turtle_72's Avatar
turtle_72
turtle_72 is offline
Electric door lock
hey guys on my '88 I had a similar problem with my pasenger side door lock. Check to see if the motor is working and getting power.Min had simply come unhooked.
Good luck
Curt
Old 10-01-2002, 05:00 PM
Hawk521's Avatar
Hawk521
Hawk521 is offline
Electric door lock
My real question is whether or not it is SUPPOSED TO unlock/lock the driver's door? I can see how Ford (always a better idea) could argue to themselves that the driver's door doesn't need an electric lock.
Also - should turning the driver side door key lock open or lock any other locks?
Just trying to understand how it is supposed to work. I might not have any problem at all.
Old 10-01-2002, 05:36 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Electric door lock
Good point Hawk, Perhaps a eyeball cruise through the owner's manual would help.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old 10-02-2002, 11:17 AM
mtuchris's Avatar
mtuchris
mtuchris is offline
Electric door lock
I had the power lock on my passenger door die a year ago on my 89 XLT It turns out that it just started to get a little gummed up because it was old. The problem started when the winter hit and the low temps made the grease really tacky, by summer it didnt work anymore so i simply replaced the motor and its been fine ever since. Now the drivers side lock is begining to get gummed up itself and i will probably have to clean it out or replace that one too by the spring. But in response to Hawk's question, both locks should be power, at least in an 89XLT.
--Chris
Old 10-02-2002, 02:03 PM
damquick's Avatar
damquick
damquick is offline
Electric door lock
had the same thing on my 89 b2, just take them(the motors) out. be careful not to lose the little ball bearings, and clean them really well with wd40. replace them in reverse of removal and while your at it smear them with some white lithium grease. white lithium doesn't
freeze and will last a lifetime, and while your at it why not grease the window tracks and lock mechanisms while your in the horrible, one arm in and cramped position anyway..lol....good luck.
Damquick
Old 10-02-2002, 02:57 PM
motorbreath
Electric door lock
yes its supposed to work, and no key doesnt auto-unlock all doors.
Old 10-03-2002, 08:33 AM
Hawk521's Avatar
Hawk521
Hawk521 is offline
Electric door lock
Thanks for the help. I think I now know what needs to be done.
Is R&R of the door panel a job for a novice? Any tricks to it? Seems like years ago in another lifetime I pulled a door panel off and lived to regret it.
Old 10-04-2002, 07:39 PM
damquick's Avatar
damquick
damquick is offline
Electric door lock
[updated:LAST EDITED ON 04-Oct-02 AT 08:39 PM (EST)]Yeah the R&R is simple actually. Just remember the screws in the bottom of the door panel and be careful around your door handles not to crack the plastic bezels, they go for about 8 bucks each at the dealer if you can get them. And put a cup under the power lock assembly in case a bearing drops down, took me about 1 hour to fish one out of the bottom of the door once with a magnet and they are small!!!
Old 10-07-2002, 12:43 PM
Steamerr's Avatar
Steamerr
Steamerr is offline
Electric door lock
tomrflorida
31
02-15-2014 08:49 AM
aussiecowboy
05-29-2012 10:31 PM
sthrnforddriver
09-21-2010 10:42 AM
jjs2032
04-22-2008 08:27 AM
Quick Reply: Electric door lock
