Valve train problems 352
Old Sep 22, 2004 | 05:44 PM
original67's Avatar
original67
I just got my engine up and running again, and I started hearing a ticking noise, I just figured it was a stuck lifter, so I drove it to school, and began to find out what was wrong, I noticed that the rocker arm for the exhaust valve, on the #6 cylinder, was not in contact with the top of the valve, it was resting on the edge of the valve spring, so I diagnosed my ticking problem, well, I then noticed that the rocker arm had been banging against the retainer that is on top of the valve spring, that holds the valve in place, so I was just seconds away from dropping a valve, I then noticed that the pushrod for the intake valve on that same cylinder was bent very badly, what is the problem with this?
Another Question, What does the keeper/retainer look like that is on the top of the valve spring, the one I looked at at the parts store, was a two piece keeper, that was cone shaped, and kept the valve in the valve spring, is this the correct part?
Old Sep 22, 2004 | 06:56 PM
FORD352V8's Avatar
FORD352V8
My guess would be a bent rocker shaft. Try replacing them both and of course replace the bent pushrod.
Old Sep 23, 2004 | 05:05 PM
390fe's Avatar
390fe
There's a good tech article written on FE valvetrain that you may benifit from. Look here:
https://www.ford-trucks.com/article/article.php?id=106
lannondiesel
Oct 14, 2014 06:12 PM
queen of spades
Oct 12, 2013 03:45 PM
crescentwrencher
Jun 2, 2008 08:45 AM
wyldstallyn73
Mar 27, 2005 12:11 AM
Alz Ryde
Dec 30, 2003 09:16 AM
