Specifics and 8.8" Explorer Install
Old Oct 2, 2004 | 07:24 PM
  #46
rtcalabrojr's Avatar
rtcalabrojr
Darksider
so how do you set the motor and trans? offset ? or does it mater?
Old Oct 2, 2004 | 07:27 PM
  #47
Christopher2's Avatar
Christopher2
Veteran: Navy
My motor and transmission are pointing straight back. The rearend is pointing straight forward so they are parrallel. The only angles I have to worry about are the motor angle up and down and the rear end angle up and down.
Old Oct 2, 2004 | 08:51 PM
  #48
rtcalabrojr
Darksider
but if you center the rear in the frame, the drive shaft is off to the pass side? thats what i mean. i know about the motor and trans. rear all being parallel.
Old Oct 2, 2004 | 11:02 PM
  #49
CIAF's Avatar
CIAF
RT, Please read the post by John Niolon on Pinion angles. It is clear ,concise and to the point. I followed his instructions last week and the task is done and and it was done in short order. (Thanks Niolon) Heres the link...go get-em
http://www.clubfte.com/users/jniolon...nephasing.html
Old Oct 2, 2004 | 11:26 PM
  #50
rtcalabrojr
Darksider
El Cabron,i have read the post and it does not say how far off the offset could be? You say you did this task last week, what motor and trans and rear did you use? about what is your offsets? Thanks RT
scoutbuff
Bronco II
May 25, 2015 03:00 PM
dferrell5
30
Jan 25, 2014 01:26 PM
dferrell5
Dec 30, 2013 04:24 PM
thdarragh
Jul 24, 2013 11:52 PM
rzns60
Sep 3, 2011 04:33 PM
