Spark Plug Change- Service Engine Soon Light
Old Sep 22, 2004 | 07:30 AM
mcn420's Avatar
mcn420
Question Spark Plug Change- Service Engine Soon Light
I just changed the spark plugs on my 5.4L Y2K X this weekend. (installed Autolite Double Platinums) After all was done we fired the truck up and the "Service Engine Soon" light came on. Turned out that I left one of the coil packs (cops) unplugged, after plugging it in the light stayed on. I disconnected the battery for 5 minutes and after that, the light went out and the truck ran great for two days. Then yesterday afternoon the light popped on again after I started it, which was the 2nd time the truck was run that day. I drove it this a.m. and it seems to still run good, but these dang OHC motors are so smooth I could barely tell one of the cylinders wasn't firing when the COP was unplugged.
1. Any idea what may have caused the service light to come on, especially considering the work I did?
2. Can you get the trouble codes on new Fords w/out a code scanner (like the Chryslers by turning the ignition on and off a certain number of times)?
Old Sep 22, 2004 | 10:02 AM
buzzard's Avatar
buzzard
My bet would be ignition related, i.e. another improperly attached coil pack, but it could be a number of things. Best bet is to have the code read with a scanner....the only way you can read the codes. Autozones do it for free.
Old Sep 22, 2004 | 10:54 AM
mcn420's Avatar
mcn420
Sounds good, i'll try to stop by AZ tonight on the way home.
Old Sep 22, 2004 | 11:05 AM
Cisco Kid's Avatar
Cisco Kid
When I changed my plugs, the same thing happened to me. The problem was a coil pack was not connected correctly. Once I fixed it the light didn't go off until I unplugged the negative on the battery and reset the computer. Since then I have not had a problem.
Old Sep 22, 2004 | 11:14 AM
mcn420's Avatar
mcn420
Thanks FCV, but was the COP not plugged into the sparkplug right, or the snap on electrical connector? I was afraid some of the COPs may have not slipped over the spark plug right, especially on the rear plugs, but I'm assuming they make those to slip over the plug itself????
Old Sep 22, 2004 | 11:24 AM
Cisco Kid's Avatar
Cisco Kid
For me it was a coil pack not seated all the way, but a buddy of mine had the engine light come on because he forgot to hook up the cable to the coil pack. It is one or the other. "Yes, it slips over the recesed plug."Typically if you broke something, you would know it. Just inspect your work one more time and make sure everything is connected. Once you have done that, turn the vehicle on and make sure it is not missing. If the engine is running smooth and the light doesn't turn off, just unplug the negative on the battery for about 30 minutes. The hook everything back up and set your clock.
Old Sep 22, 2004 | 11:37 AM
mcn420's Avatar
mcn420
oh and don't forget the 18 radio stations, all your average fuel mileage and tripometer are reset too, LOL I will check all that stuff again and / or get the OBD code read. Thanks again!
Old Sep 22, 2004 | 03:45 PM
kimchee's Avatar
kimchee
Do you guys know if using a different brand coil pack for one cylinder is bad?
Im not about to spend $130 for one from Ford if I can get one for $50.00 at kragens.
Old Sep 22, 2004 | 04:04 PM
Cisco Kid's Avatar
Cisco Kid
I had to replace one of my coil packs and I used the Napa Auto brand. I believe it was Autolite. I have not had any issues at all. I would say non-Ford is ok.
Old Sep 23, 2004 | 08:44 PM
brian noyes's Avatar
brian noyes
Exclamation
After All The Blood And Swearing Changing The #4 Cop (thanks To A Good Scan Tool Telling Me What Cylinder Was Misfiring) That Is The Rear On The Passenger Side By The Way--- I Would Not Use Anything But An Oem. I Paid 100 At The Ford Dealer.good Luck
Old Sep 23, 2004 | 09:05 PM
mcn420's Avatar
mcn420
My code was P1405. Turned out one of the emissions hoses that went from the throttle body to the DS exhaust manifold that the end tore off during the spark plug job wasn't long enough (I stretched it & got it back on) came off again. Now with a new rubber emssions hose all is well again with the SES light. BTW if that hose is off, you DON't have an exhaust gasket leak, it just sounds like it. I'm thankful of that b/c I thought the exhaust manifold I fixed right before the new spark plugs was leaking again.
KeyKeeper
Modular V8 (4.6L, 5.4L)
17
Jun 21, 2017 09:24 AM
JeffHWV
Jul 15, 2016 11:17 PM
dbrydon
Feb 8, 2016 08:20 AM
AlbanyHDTV
Sep 14, 2009 01:51 PM
Schooner 45
Modular V10 (6.8l)
Aug 23, 2009 08:45 PM
