1978 - 1996 Big Bronco
where is the fuel filter?
Old Sep 21, 2004 | 09:24 PM
1986 bronco eb's Avatar
1986 bronco eb
hi, everyone I been looking for the fuel filter on the frame but the only thing I can find is a big black can covered by a metal. I also found the inline gas pump. No fuel filter.
Old Sep 22, 2004 | 12:14 AM
justshootme84's Avatar
justshootme84
right under the driver's seat, on the inside of the frame. Not in the cab, but underneath.
Old Sep 22, 2004 | 06:55 AM
fcarruth's Avatar
fcarruth
Like justshootme84 said, it's under the driver seat on the frame. If you found the fuel pump, it is about 1 foot closer to the engine, usually behind a brassy looking piece of protective metal shield.
Good luck,
Old Sep 22, 2004 | 04:12 PM
djjoshuad's Avatar
djjoshuad
also, I hope that the lines are easier to remove on yours than they are on my '93. the spring mechanisms can be difficult to dislodge, even with the specialized tool.
Old Sep 24, 2004 | 06:05 PM
1986 bronco eb
I found the black big fuel filter looking can but it is around the transfer case. Under the seat area there is no filter just the pump. From the black big filter the fuel lines go to the fuel pump. After the fuel pump the lines go under the intake.
Old Sep 24, 2004 | 08:32 PM
Cloim's Avatar
Cloim
On an '86 that "black can" by the t-case has a filter inside it.
Most other years have the "reservoir" but no filter in it.
There definitely should also be a filter (inline type) between the hi-preasure (frame mounted) fuel pump and the fuel rail.
If there isn't, I'd suspect someone replaced the fuel lines and neglected to put the filter back.
Old Sep 25, 2004 | 09:03 AM
1986 bronco eb
I guess someone else had to replace the fuel lines before I had the bronco. Because there is no signs of the line missing a fuel filter. Is there any way I could add a fuel filter? Maybe cutting a peice off before the fuel pump and replacing the peice with the filter.
danevans
Escape & Escape Hybrid
Oct 30, 2025 08:31 AM
sgrol
6.7L Power Stroke Diesel
Dec 8, 2016 08:26 PM
kupaa
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Nov 7, 2010 11:10 PM
Scratcher
Jun 8, 2010 09:50 AM
CaseySirish
Jul 20, 2009 11:01 PM
