5.8 w/5.0 upper intake.
Old Sep 24, 2004 | 05:32 AM
EPNCSU2006's Avatar
EPNCSU2006
You have some hotrod motor though... I have an intake manifold from a 351 and the throttle body on there was the same size as the one on my 302.
Old Sep 24, 2004 | 09:58 PM
Cloim's Avatar
Cloim
Originally Posted by EPNCSU2006
^ what spacer? Do you have a picture?
Just refering to the middle of the intake. 4 runners closely spaced, big space in center, then the other runners are closely spaced.
302 runners are (roughly) spaced equally from front to back.
Having a 302, this isn't something I've looked too deeply into. If I had a 351, I'd go buy a 302 intake gasket, put it on top the lower intake, and decide for myself.
As it is, I'm now going by what your saying.
Old Sep 26, 2004 | 08:14 AM
EPNCSU2006's Avatar
EPNCSU2006
The 302 has an egr passage in the lower intake manifold, in the big space between the front 4 runners and the back 4. The distance between the ports should be roughly the same.
Old Sep 27, 2004 | 02:38 AM
pfogle's Avatar
pfogle
From what I can tell, the motor is stock, minus a possibility of a cam... This may be a stock item as well though.. There are some rumors of a HD 351 in the early 90's but I have not been able to confirm it...
truebluehero
Nov 7, 2016 05:10 AM
Tim Young
1966 - 1977 Early Broncos
18
Aug 18, 2008 10:21 AM
NitrousAl
13
Jul 6, 2007 08:23 PM
lbianc1
1978 - 1996 Big Bronco
Dec 6, 2006 07:40 PM
Norm Carter
Nov 15, 2003 02:30 PM
