power window motor
Old Sep 21, 2004 | 05:22 PM
dino360's Avatar
dino360
Angry power window motor
does anyone have a link to a detailed window motor rebuild? Mind is out and it is not the plastic gear inside.
Old Sep 21, 2004 | 07:57 PM
broken wire's Avatar
broken wire
The problem usually is not the plastic gear, it is the three little white/opague plastic cylinders that go between the triangle and the outer housing, they discinagrate to nothing, then the motor sits and spins and the window does not move, I heard of some guys the other day that used cuts of wooden dowel rod, used in place of the plastic cylinders and got there windows to work. Broken Wire
Old Sep 21, 2004 | 08:47 PM
MemOrex's Avatar
MemOrex
Yea it could be those 3 plastic 'bushings'. Was there a bunch of broken plastic when you opened it? If its the motor that doesnt work at all, I dont think theres gonna be any pages describing how to rebuild. A new one is relatively cheap ($50).
Old Sep 21, 2004 | 09:20 PM
dino360's Avatar
dino360
Angry
It is definately not those 3 rubber deals. I have had that problem before. When it is those deals, the motor still operates. Mine has no operation at all. I am planning to open it up and clean the brushes and the electrical contacts but I am trying to find a link that details the operation.
Old Sep 22, 2004 | 07:15 AM
pctours's Avatar
pctours
Power window motor
If the motor doesn't run at all, it is either the door switch or the motor. The motors seldom go out, but the brushes wear out. I hane repaired several by pulling the brushes from an old drill, edger, or electric chainsaw and using them. Had to "size them down" a little using a piece of emeory cloth and solder the leads. Don't know where you can get new brushes (I couldn't locate any).
Old Sep 22, 2004 | 08:31 AM
phordphella's Avatar
phordphella
got a replacement for mine for $50 at auto zone, with lifetime warranty. the only thing was that only two of the bolts lined up, not all three. but, it has worked good for almost a year.
Old Sep 22, 2004 | 08:38 AM
GLR's Avatar
GLR
No link to detailed rebuild, but as long as the switch is ok, the motor is similar to starter motor. 2 bolts holding end plate on, lots of times brushes need freeing up. Then a little sealer around end cap. My 89 CV is still working after a "free-up" job about 6 yrs ago.
Old Sep 24, 2004 | 12:12 AM
dino360's Avatar
dino360
Angry
I know it is not the switch, I get power to the motor. I hook the motor to a power supply and it just makes a little noise like it wants to do something. I took the thing apart and it is pretty simple. I cleaned the two metal pieces held in place by springs ( I am not sure what they are called, brushes?) as well as the area that rotates where they make contact. The motor started to move when connected to power. I started tapping on the motor case to see if that would help but no luck. I reopened it to see if it possibly needed more cleaning and found that the tapping cracked on of the two magnets located inside the case in half. I don't guess I can repair it now.
Old Sep 24, 2004 | 08:17 PM
broken wire
broken magnet repair
If the magnet is just broke in two pieces but still in the case solid, put it together as it is, if the magnet has broken apart from the case and in two pieces, glue the magnet back into the case with a five minute epoxy and a small "c" clamp. If the magnet has fallen out and broken in two pieces, well then you have to have something to go by to locate which pole is north and the other south and put the magnet back in the case in the correct orientation. By the way, a broken magnet has been proven to perform very well. broken Wire
Old Sep 24, 2004 | 08:28 PM
Blurry94's Avatar
Blurry94
Same here....replaced one on my 90 and all is well.
Old Sep 25, 2004 | 11:17 AM
spankydxm's Avatar
spankydxm
my motor sounds weak and it also jumps do you think it is the three plastic pins?
Old Sep 25, 2004 | 11:40 AM
omni's Avatar
omni
dino 360 can I ride on your thread with a question? the drivers side electric motor for the window seens like its on NOS, if I push the button from full closed or full open it gets so wound up it all mosts breaks the glass when it finishes, anyone heard of this one?
Old Sep 25, 2004 | 12:16 PM
spankydxm's Avatar
spankydxm
dont they have an adjuster nut on top of the motor itself?
Old Sep 25, 2004 | 01:16 PM
dino360's Avatar
dino360
Angry
I had an old motor laying around that was for a tailgate wondow and was the wrong way like the passenger door. My broken one was out of the driver side. All I did was take both motors apart and switch the heads. I installed the motor last night and it works fine. I would still like to hang on to the broken one and try that fix that Broken Wire talks about. What does that adjuxting screw on the end or the motor adjust any way? Maybe it controls the speed and could fix Omni's problem?
Old Sep 25, 2004 | 11:33 PM
MemOrex's Avatar
MemOrex
Adjuster Nut? I might've missed that when i fixed my window.
Omni, check the voltage thats running to the motor.
