Big Problem! Please HELP
Old Sep 21, 2004 | 04:59 PM
FAB150's Avatar
FAB150
Exclamation Big Problem! Please HELP
My truck just hasnt been running these past few weeks so i decided to throw in a new set of spark plugs. I have the 4.6 in a 98. I got the plug on cylinder 4 in the back passenger corner, pulled the plug wire off, tried to stick my socket down in there, and nothing. The socket woldnt go down far enough to catch anything. I could stick my finger down there just enough to feel that the top of the spark plug the screws on was bent. I have tried for about an hour to bend it back with no luck. This really sucks because i have to be at work in 5 1/2 hours. Does anyone have an idea on how in the heck to get this thing out.
Old Sep 21, 2004 | 05:04 PM
ejpreston's Avatar
ejpreston
did you try unscrewing that little piece and then try to get the socket back on? Sorry, that's all I got...good luck.
Old Sep 21, 2004 | 05:07 PM
FAB150's Avatar
FAB150
I am unable to get anything down there that could unscrew it. I think it is bent with the tip of it toward the wall off the tube. Thanks though.
Old Sep 21, 2004 | 05:13 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Get a mirror and a flashlight in there and see what's going on. Perhaps a needle nose pliers or smaller pliers will remove that tip. I cautiously suggest bending the tip; it may not need to be perfect but instead just good enough to get the socket on the plug.
Old Sep 22, 2004 | 01:01 AM
FAB150's Avatar
FAB150
This isnt a engine specific question but if it needed moved in your eyes great job. Still no luck. Ran out of light and I am going to bend something to fit under the bend to try and pull up the tip enough to get the socket down. If this dont work, how hard are the spark plugs to break? The porcelain area specificly.
Old Sep 22, 2004 | 07:24 PM
LxMan1's Avatar
LxMan1
Should break pretty easy. The you will have a bunch of debris in your plug pocket and when you remove the plug, it will fall into the cylinder unless you blow it out first.
I have never seen one bend like that, I wonder if the plug started to blow out and got cocked and didn't come all of the way out?
Old Sep 23, 2004 | 03:32 AM
FAB150's Avatar
FAB150
Well tonight I definetly broke it into pieces. It is not bent anymore but to get it straight again i broke the porcelain into pieces. Im taking the compressor and tank home from work in the morning to try to blow the pieces out. Should that get most of it out. Any other ways to get all that crap out of there.
Old Sep 23, 2004 | 09:10 AM
cbsaf's Avatar
cbsaf
Double sided tape stuck on a pencil will pick up the very small dust sized peices of porcelain. Just take out the large peices first and blow out the hole and dont lose the tape.
Old Sep 23, 2004 | 03:53 PM
FAB150's Avatar
FAB150
Just wanted to thank everyone for there input and help. I was able to blow the broken pieces out with 130 psi. Im trying the bosch platinum 2. I have heard both sides of these equally so the only way i will know i guess is to try them out myself.
Old Sep 25, 2004 | 12:42 PM
LxMan1's Avatar
LxMan1
I will never use Bosch again. Their center electrodes are known to fall out and ruin engines. Got my Dad's 5.0 a couple of years ago. These trucks run best on either Motorcraft of Autolite Double Platinums.
sammie0126
Sep 10, 2025 06:56 AM
doughogan
2009 - 2014 F150
Oct 11, 2016 02:29 PM
f250mtnbikr
Jul 9, 2016 10:27 PM
Rasputin53
Nov 20, 2015 05:23 PM
93F250
Modular V10 (6.8l)
Sep 15, 2008 11:55 PM
